EAGLE User Support (English) ATMEGA32U4  QFN-44-NOPAD package pin spacing
  • Views 714 views
  • pin
  • spacing
  • atmega32u4
Pedro147
Pedro147 over 10 years ago
Hello I am very new to Eagle and I cannot find out how to get the pin spacing on an  ATMEGA32U4-MUATMEGA32U4-MU QFN-44-NOPAD package.from the SparkFun-DigitalIC library I realise it is more than likely on the datasheet but I may as well be reading Chinese at this stage image I need it so I can adjust my grid size on the board and get the pads lining up perfectly. I would appreciate some help thanks Pedro
  • Pedro147
    0 Pedro147 over 10 years ago
    Thanks for your reply and yes I will have to apply myself to find the answer. It is an existing circuit in a flight controller and this is the correct package.
    0 shabaz over 10 years ago
    It may look like Chinese but you do need to examine it and get over the hurdle once and for all. You're looking for a mechanical layout, often at the end of the datasheet, but sometimes in a separate document.
    For QFN it could be 0.5mm (this is popular), but other values are possible.
    Also for QFN, are you aware it is quite difficult to hand-solder without quite some practice? Is it really the package you want, or did you intend QFP or DIP?
