EAGLE User Support (English) need help finding eagles libraries
  • Subscribers 177 subscribers
  • Views 713 views
hi i'm new to using eagle and could do with libraries that contain the following ics (SURFACE MOUNT)
74HC374
74HC04
74HC74
AD722
555
    1)74xx logic chips: library 74xx-us (or 74xx-eu). You may have to change
    the part description to 74HC whatever.
    2)AD722: this is not in the Analog Devices library, so you will have to
    make your own, although you could ask to see if anyone has already done
    that.
    3)555: do a search for "*555" - there are several results.
