EAGLE User Support (English) Error (sound) when trying to delete a component, OK when zoom out
  • Replies 10 replies
  • Subscribers 187 subscribers
  • Views 1249 views
  • zoom
  • delete
richard@driessen.net
richard@driessen.net over 11 years ago
I've a component (from my custom library) that I place on the schema, but when trying to delete is (or move etc.) a sound is heard. No error message no information at all, and the component is not deleted.
But when I zoom out (so that my component is very tiny) then I can delete the component.
Deleting the component after selecting zoom to fit, give the same error sound.
How can I delete / move the object without zooming out completely?
  • richard@driessen.net
    0 richard@driessen.net over 11 years ago in reply to autodeskguest
    @Joern Paschedag: you put me on the right track. I'm ashamed to say that I did not know I had to click the cross on a device to select it. I thought a random place would be fine. By placing the center of the device in the center of the library-element, the cross appeared and it became obvious to me that I had to click the cross.
    I guess zooming out makes it easier to click on the cross ....
    0 autodeskguest over 11 years ago in reply to richard@driessen.net
    Richard Driessen wrote on Wed, 28 October 2015 04:17
    Good idea Joern. Here is the link:
    https://onedrive.live.com/redir?resid=F67796BA2A931950!390901&authkey=!
    ADIow6lLIuFpNI4&ithint=file%2clbr
    http://www.element14.com/community/message/165261
    You can't have tPlace silkscreen covering pads! If you need lines covering
    pads, move them into the tDocu layer.
    Am 28.10.2015 um 09:17 schrieb Richard Driessen:
    https://onedrive.live.com/redir?resid=F67796BA2A931950!390901&authkey=!ADIow6lLIuFpNI4&ithint=file%2clbr
    Your origins are on the pin1 ends in both symbols!
    That is not really wrong, but as you have seen you never find them again image
    Usually one draws a symbol so that the origin is in/near the middle.
    This has the advantage that the symbol is not swinging too far away from
    its position if one rotates it.
    Then if you add your symbol to the device, the origin should hit the 0,0
    in device editor.
    Your packages have the origin in the centre.
    HERE some people prefer to have the origin on pin 1 of the package.... I
    don't image
    General you should  read the" help pin" for the directions of the pins
    in your symbols if you want to use the ERC of eagle. And perhaps make
    the symbol bodies a little smaller image
    Joern Paschedag
    sound.
    If the part has a refdes, type "move ".
    Good idea Joern. Here is the link: https://onedrive.live.com/redir?resid=F67796BA2A931950!390901&authkey=!ADIow6lLIuFpNI4&ithint=file%2clbr
    Am 27.10.2015 um 19:24 schrieb Richard Driessen:
    The center (0,0) is somewhere in on the edge of the symbol. If I use
    zoom-to-fit in the library the symbol shows normally (fills the windows
    it is in).
    http://www.element14.com/community/message/165211
    OK.
    So to avoid guessing around here send that device here in a library.
    Joern Paschedag
    The center (0,0) is somewhere in on the edge of the symbol. If I use zoom-to-fit in the library the symbol shows normally (fills the windows it is in).
    0 richard@driessen.net over 11 years ago in reply to spiritualmadman
    If I select only the Symbols layer, the issue persists.
    Am 27.10.2015 um 16:28 schrieb Richard Driessen:
    sound.
    http://www.element14.com/community/message/165176
    Probably the  origin of the component is not in it's centre, but far out
    in the galaxy image
    If you zoom out perhaps the snap function catches it...
    Check your library symbol and verify that the 0-0 coordinate is in the
    middle of your symbol.
    Joern Paschedag
  • spiritualmadman
    0 spiritualmadman over 11 years ago
    Try turning off layers until only the components/symbols/devices you are after are showing.
    As far as zooming out making a difference in deleting a part that is the exact opposite of what I'd expect.
