EAGLE User Support (English) ICSP Header
  • Subscribers 178 subscribers
  • Views 579 views
ICSP Header
KeithSloan
KeithSloan over 10 years ago
I want to create a small PCB that will act as an ICSP header for a PC16F877A i.e. The Board will use a stand off connector which plugs into the original circuit board with the PIC. How do I get the appropriate bottom layer for the small header board
    Keith Sloan wrote on Wed, 28 October 2015 09:18
    into
    http://www.element14.com/community/message/165335
    I'm not sure I understand the question, but a through-hole header will have
    pads on both sides of the board. If this is a commercially made board, then
    you can have traces on both sides of the board. If this is homebrew, and
    the header is mounted on the bottom side, then you need traces on the top
    side. HTH
  • e14candies
    0 e14candies over 10 years ago
    Also, I am tired of Eagle packing my 6 long traces 8 mils apart when there
    is 1/2 inch of room all around---they could easily have 40 mil separation.
    But you can't simply set it for 40 mil, since in many areas (such as at
    the chip pins) 40 will would never work & the routing fails.  There should
    be an option to optimize spacing with different preferences (in some case
    you do want them packed tight together)
    0 autodeskguest over 10 years ago in reply to e14candies
    eaglecandies wrote on Mon, 07 December 2015 23:21
    Also, I am tired of ... <remainder of whine snipped>
    First, your emotional state is not our concern.
    Second, what does this have to do with ICSP headers?  I don't know whether
    you can't read the topic or deliberately tried to hijack someone else's
    thread, but either way neither you nor your post belong here.
  • e14candies
    ooops got posted on the wrong thread
