EAGLE User Support (English) vscore layer not visible in Eagle 7.4.0
  • Subscribers 177 subscribers
  • Views 1019 views
  • layer-102
  • vscore
I have layer 102 vscore in previous Eagle versions. Eagle 7.4.0 stops at layer 52 bDocu.
I need to prepare a panel and thus I need vscore.
Thank You
Note: This is still not answered. The blog marked it as answered.
Message was edited by: Glenn Jackson
    Not Answered. Failed trying to change back.
    http://www.element14.com/community/message/166849
    layer 52 bDocu.
    Thank You
    Layers over 100 are user defined layers so some time in the past you
    must have defined the layer oe used a library part that had established it.
    See HELP > Editor Commands > Layer > Define layers
    HTH
    Warren
    layer 52 bDocu.
    have you read the online help for the layer command?
         layer 102 vscore
    or "new" in the layer menu
    should do the trick
    Lorenz
