EAGLE User Support (English) Why are the Title Block global attributes blank?
  • Subscribers 177 subscribers
  • Views 253 views
  • block
  • title
Kybor
Kybor over 10 years ago
I have DOC_NUMBER, REV etc. entries in Edit/Global attributes, but they don't appear in the frames/FRAME_B_L title block in one of my schematics. The other schematics using the same frame are fine. I've deleted and re-added the frame, used Save All, closed and re-opened the project. I deleted all the Edit/Global attributes, Save, close project, re-open project and entered them again. What could be preventing COMPANY_NAME, etc. from showing up in this one diagram?
    The frame is a Library Device
    In the library you can see that the Device is made up of a two Symbols
    One of them is the DOCFIELD
    In the DOCFIELD Symbol you need to have a field name like >Company
    before the value of your Global attribute 'Company' will be inserted
    when used in the schematic.
    The manual explains this on page 128 (v7-2-2)
    HTH
    Warren
