EAGLE User Support (English) Can't Route Arduino
  • Replies 8 replies
  • Views 2026 views
  • board
  • packages
  • routing
Can't Route Arduino
I am using the standard edition of Eagle 7.5
I have grabbed an Arduino Micro from the Element 14 library (E14_Arduino_revB.lbr).  I placed this device on a board expecting to have the board drilled out for the pins of the Micro to go into and to route traces from these holes to other device on the board.  (This seemed like a simple enough thing to do).
BUT...
1)  AutoRouter refused to route any air traces to the Arduino pins.
2)  Manually attempting to route a trace to the Arduino pins refuses to obey
3)  Routing any trace anywhere near the Arduino turns the cursor into a Do-Not-Enter sign (circle with line through it).
SO (BTW, if you haven't figured this out yet, I am new to Eagle)
Is this something wrong with the library object?
There don't appear to be any routing exclusion zones in the exclusion or restrict layers in the package.
WHAT do I do?  How do I make this work?
  • rachaelp
    0 rachaelp over 10 years ago in reply to e14 Contributor
    Hi Kingsley,
    Decent libraries are the achilles heel of most ECAD tools out of the box
    unfortunately. Even the very expensive tools usually ship with garbage
    libraries. I wish they'd just create a very small but well done set of
    example / starter libraries with a good set of default symbols and IPC
    compliant packages to give people a solid base upon which to build their
    own. Having tens of thousands of completely varying quality and randomly
    sorted libraries does little to help anybody get started quickly and get a
    good quality board designed.
    But libraries in Eagle are probably more of a problem than some other tools
    due to the way they work. Having to have duplicated footprints across
    multiple libraries because you need a particular package for some very
    different devices which don't sit nicely within the same .lbr in a well
    structured library is a real pain for example. They have improved the
    library manager hugely over recent releases which is great to see, it's
    definitely a lot quicker to manage where everything is now and get to
    things within a library for editing than it was so I am hopeful they have
    even more improvements coming in the future but whether they'll make any
    fundamental changes to help enable having a better library structure....
    Anyway, I'm glad to hear you came to the same conclusions as me and got
    your problem sorted, good luck with the rest of your project image
    Best Regards,
    Rachael
    0 e14 Contributor over 10 years ago in reply to rachaelp
    Rachael,
    EXACTLY.  So I noticed.  It is sort of a let down that the published libraries are not useful--even from seemingly affiliated sites.  When I didn't get any useful answers on here (before yours), I created my own Arduino MICRO, mainly just to test whether there was something wrong with the library.  To my (not really) surprise my MICRO wired up just like it should have.  SO... you are right.  The library is wrong.  ...and the problem is solved doing basically what you suggested.  Thank you!
  • rachaelp
    0 rachaelp over 10 years ago in reply to autodeskguest
    Hi Kingsley,
    David's answer above is a clue but I think the underlying problem is the
    library part doesn't do what you (or I when I first looked at it) were
    expecting. If you load the library part into the library editor and examine
    it you'll see that:
    a) It's got its bounding box on the dimension layer (i.e. how you draw a
    board outline).
    b) It's got SMT pads where the USB connector is.
    So basically it's defining itself as a board and confusing the auto router.
    If you put components within the bounding box of the Arduino board then you
    will find the auto router will route to them (I have just tried and it
    does).
    Interestingly I can manually route the connections whereas you can't so you
    have another issue going on there. Have you loaded any design rules or
    anything?
    I'm not sure what the original purpose of this library is. It provides a
    symbol like it's defining a component but then provides things you couldn't
    route to if you put it on a board (you can't route to the SMT USB pads if
    you were to place an Arduino Micro on the board using the through hole pads
    provided) and it also provides a board outline rather than a placement
    outline  so screws up routing to it (if you use the auto router at least).
    I guess if you are wanting to create your own variant of an Arduino Micro
    it might be useful but that's a very limited use case I would have
    thought.
    My personal opinion is it's not a particularly useful (or well designed)
    library and you should probably just create your own library for what you
    want to do. This is actually the best thing to do in most cases anyway as
    bundled "free" libraries (as with pretty much ALL schematic tools, not just
    Eagle) or ones downloaded from the internet are generally not ideal to use
    and you really need to thoroughly check anything you haven't created
    yourself anyway (or risk having to rework or worse scrap off a batch of
    boards if a library contains any errors) so you are better off just
    creating your own trusted libraries in the first place.
    Best Regards,
    Rachael
    You need to move the parts onto the board before you can route the traces.
    Initially, EAGLE places all parts outside of the board. All parts must be
    within the board outline.
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Thank you for the reply.  I have attached a VERY simplified schematic
    and board which has exactly the same issue with the Arduino Micro
    component.
    Note that all traces between other components route BUT, that no traces
    which go to the Arduino ever route.
    I am happy to believe that I have done something wrong.  I just need to
    know what it is.
    If there is something wrong with the library component I am willing to
    fix it and share the revised part.
    Thank you.
    http://www.element14.com/community/message/167375
    0 e14 Contributor over 11 years ago in reply to autodeskguest
    Thank you for the reply.  I have attached a VERY simplified schematic and board which has exactly the same issue with the Arduino Micro component.
    [I tried uploading the actual schematic and board file from Eagle, but the forum keeps telling me 'The content type of this attachment is not allowed."]
    Note that all traces between other components route BUT, that no traces which go to the Arduino ever route.
    I am happy to believe that I have done something wrong.  I just need to know what it is.
    If there is something wrong with the library component I am willing to fix it and share the revised part.
    Thank you.
    component.
    know what it is.
    Thank you.
    http://www.element14.com/community/message/167373
    I just downloaded the library and looked at the Arduino Micro library part.
    All I see is the board outline, mounting holes, and connectors. There is
    nothing for the auto-router to do since there aren't any air-wires. Could
    you post your schematic and board so that we can see what problem you're
    having?
