EAGLE User Support (English) Comparing ".brd" files
  • Replies 8 replies
  • Subscribers 186 subscribers
  • Views 2330 views
  • .brd
  • eagle
  • pcb
  • comparison
SMD111
SMD111 over 10 years ago
Is there a ULP which can find and show the differences between two layouts?
Thank you.
  • rachaelp
    0 rachaelp over 10 years ago
    SMD111 wrote on Wed, 25 November 2015 19:10
    layouts?
    Thank you.
    http://www.element14.com/community/message/167684
    This might be useful: https://pypi.python.org/pypi/eagle_automation/0.1.12
    I haven't set it up and got it working myself but I have used it as one of
    my clients set it up on their site. Basically they had it set so you could
    check two versions of a board into git and then show the differences
    visually between the two boards by way of a "heat map" of where the changes
    were. It worked on schematics too and made reviewing changes and breeze.
    Best Regards,
    Rachael
  • Joop14
    0 Joop14 over 10 years ago
    I use the "diff" command. Works fine for me.
  • SMD111
    0 SMD111 over 10 years ago in reply to rachaelp
    Thank you, but I know nothing about Python.
  • SMD111
    0 SMD111 over 10 years ago in reply to Joop14
    I do not find the "diff" command. Just to clarify, I use EAGLE 6.4 Professional for Windows.
  • rachaelp
    Eagle Professional on Windows isn't a limitation to doing what has been
    suggested.
    You could use Windiff which will show you the changes in the XML board file
    but the down side is it's very low level and not in any graphical format
    which works fine but people some may not like viewing changes like this.
    You can install a Python interpreter for windows and then follow the
    instructions in Eagle Automation and hopefully get that working (I haven't
    tried but it should be possible). It'll be more work but if it does work
    then you'll have something that will give a graphical representation of
    where things have changed.
    Do you put your .brd file into a version control system like Git? If so
    then you could look at the differences in there too at a basic textual
    level (as per diff as it will do this within the VCS) and the bonus with
    git is that if you were to get eagle automation working you could then see
    visible differences between different board versions stored in git.
    Other than that I don't have any other suggestions I'm afraid. You might
    want to think about putting it as a suggestion for a future version of
    Eagle in the eagle.suggest forum.
    Best Regards,
    Rachael
  • Joop14
    0 Joop14 over 10 years ago in reply to SMD111
    One of the many reasons I switched to Linux. You can install "diff" on windows if you like from here:
    http://gnuwin32.sourceforge.net/packages/diffutils.htm
  • SMD111
    I did not realize that the ".brd" file format is XML.
    Of course I can find many ways to compare text files. The problem with that is that undone edits still show up as differences: if I rip up a trace, then rout that trace again and save under a different name, I will still have the same exact board but two different files. It would be much better to be able to view the differences.
    So I took it to the next level and decided to compare the actual Gerber files generated from two .brd files.
    Gerbv (http://gerbv.gpleda.org/) uses different color for each imported layer, so I was able to immediately see the difference between two ".cmp" files (or ".sol", etc). I guess this is the simplest way to compare boards, although somewhat slow.
  • eduardodemier
    0 eduardodemier over 10 years ago
    Am 25.11.2015 um 20:10 schrieb SMD111:
    layouts?
    Thank you.
    I solve this problem by
    - export image for both boards
    - use "Beyond Compare" to compare images.
    You will see the differences in a graphical view.
    Both steps are done with a few mouse clicks. By the way, beyond compare
    is my absolute favourite tool. I use it daily for many years now. It is
    very affordable but not free.
    Irfanview (free) allows to
    - load image1
    - invert image1
    - insert overlay (image2)
    The view of the differences is even better. Irfanview can be used
    through commandline.
    Good luck.
