EAGLE User Support (English) Mid-mount smd micro-usb connector?
  • Subscribers 187 subscribers
  • Views 1129 views
So, i recently received some pcb's i had designed, and realized i had made a mistake:
The USB connectors i have at the moment are mid-mount connectors, meaning i need a cutout in the board to connect them, and the part i used in eagle was a top-mount connector.
Now, I've already ordered the correct connectors, but i really like the mid-mount ones, which then begs the question; Are there any mid-mount micro-usb parts available for eagle?
This is the connector in question:
    Any lib part you find in a lib should be checked and verified that it
    matches your data sheet and your soldering process.
    If you checked the fit to a printout of the PCB it would have been
    discovered. On the other side finding and checking a lib part takes as
    long or longer then starting from scratch.
    The long standing advice from the users is to make your own lib's from
    scratch or other found stuff after verifying form and fit.
    Paul
