EAGLE User Support (English) Assembly Variant Part Attribute
  • Replies 8 replies
  • Subscribers 180 subscribers
  • Views 1873 views
  • variant
  • attribute
jameslittlefield
jameslittlefield over 10 years ago
I'm using Eagle 6.6 Pro and have been assigning part attributes (MF, MPN, OC_VENDOR) to my schematics and use the bom ulp to generate BOMs.    While there is much to wish for in terms of the mechanics of initially assigning attributes the process works pretty well.    I now have a project where I have some components that have alternate values so I created an assembly variant and changed the value of the component in the new assembly variant.    Everything works as expected EXCEPT that the manufacturer part number attribute for the part is the same even though its value changes from 1M to 10M between variants.    Is there a way to have separate sets of attributes in each assembly variant?
Might this work better in 7.x eagle?   Advice appreciated.
Jim
  • rachaelp
    0 rachaelp over 10 years ago
    Hi Jim,
    I've just tested this out in 7.2.0 and it is exactly as you describe in 6.6
    I'm afraid.
    It does seem quite a limitation of variants to only allow the value and
    technology to be changed within a variant and not any other attributes and
    the way of doing that seems a little clunky too. I guess it's fine for
    people who aren't trying to put in place a system that properly manages
    BOM's and need more than just value and technology.
    I personally would have expected to be able to crate a new variant, switch
    to it and then edit all properties and attributes of a component in the
    usual way. Switching between any variants would then restore all component
    properties and attributes to the selected variant. Sadly it doesn't work
    this way. Maybe there is a good reason they've implemented it this way but
    I'm not sure what as I only recently discovered the variants feature so
    haven't used it too much yet, only for specifying populated or
    non-populated parts.
    Rachael
  • jameslittlefield
    0 jameslittlefield over 10 years ago
    Thanks Rachael.   Your expectations are exactly what I as hoping to be able
    to do!   Bummer that its not improved in 7.x.
    Jim
    Jim
    Hi Jim,
    Rachael is correct. Unfortunately at the moment only technology, value,
    placement are adjustable.
    I have submitted an enhancement request to the Devs.
    Best Regards,
    Jorge Garcia
    Thanks, I also appreciate that.
    Markus
    if you assign the the value via technology, you can also assign the
    related manufacturer/vendor information as properties of that
    technology.
    Instead of changing value & manufacturer/vendor data separately, just
    change the technology and you are done.
    Lorenz
  • rachaelp
    Lorenz wrote on Fri, 18 December 2015 14:12
    technology.
    Lorenz
    Yes good point, that does work but I found it could be quite unwieldy to
    deal with setting values this way if for example you want to do this for
    say the entire E24 range of resistance values (let alone E48/E96/E192) in
    packages from 0201 through to 1812 and it became a total mess for
    capacitors. That's a heck of a lot of work to do to create that library and
    to select the value you want requires searching and/or scrolling so takes
    longer. But the plus side is, if you know your library is right then you
    know that when you select a value in this way, the corresponding attributes
    for internal / manufacture part numbers etc will get updated correctly
    which ensures things stay consistent.
    I've not got a good solution for managing keeping additional properties
    updated other than the above approach using technologies. Other tools I
    have used have been able to hook into an external database via ODBC to
    provide a searchable library of parts and the attributes get populated from
    the database when selected but this is part of a totally different
    discussion about Eagle libraries and library management in general rather
    than this thread relating specifically to variants.
    I think the enhancements suggested to the way variants work are still valid
    despite there being this possibility of a work around and they would make
    variants more intuitive to use and more flexible. I guess we'll have to
    wait and see what happens now!
    Rachael
  • jameslittlefield
    Jorge,
      Thanks for making this issue visible to the developers.   I would like to
    also raise a couple points which would make the attribute handling much
    more convenient.    In preparing for BOM generation design link will create
    some standard attributes for all the parts (MF, MPN, OC_NEWARK,
    OC_FARNELL).    IF designlink finds an appropriate part and confirmed by
    the user,  all these attributes get filled in automatically AND design link
    knows how to apply the same attribute selections to all the same/similar
    parts in the design (ie all the 1K 0805 resistors with matching package).
       If designlink cannot produce a suitable choice and you "skip" the part
    then the attributes have to be filled in manually to get a complete BOM.
    As an example,  I have a unusual size/power rating resistor and I use a lot
    of them,  designlink can't find the right part, so I have to manually fill
    in all the attributes.   Whats really time consuming is that even if I have
    10 resistors, all with the footprint,  value,  I have to manually (re)enter
    the MF, MPN, OC_XXXX) for EACH one.   It would be a huge time saver if the
    attribute dialog was enhanced to allow one to define/edit the attributes
    for a common group of parts.    Designlink is able to do this internally so
    it seems like the same functionality could be exposed in the Attribute
    dialog.
    Thanks for listening!
    Jim
    0 autodeskguest over 10 years ago in reply to jameslittlefield
    dialog.
    Hi Jim,
    I hope you're doing well. Have you tried the attrib-add.ulp that is up
    on our website? Make sure you get the latest version it allows you to
    assign attributes based on a group.
    You would just define a group that contains the parts you want to assign
    the attributes to and run the ULP.
    hth,
    Jorge Garcia
