EAGLE User Support (English) Exporting an EAGLE Schematic to a very high resolution PDF
  • Subscribers 177 subscribers
  • Views 3064 views
  • high-resolution
  • pdf
I have a very large EAGLE schematic that I would like to fit on a single PDF image. Because the schematic is so large, when zoomed out enough to fit the whole schematic, much of the circuitry/text is not visible. I need to be able to zoom in on the single PDF image and see every detail in the schematic. Is this a special file type or just a high resolution image? How can I accomplish this task?
Thank you in advance for your expertise!
    Eric Amikam wrote on Wed, 13 January 2016 16:52
    single PDF image.
    Use multiple sheets in Eagle.  A large schematic on a single sheet is
    obnoxious to anyone that has to look at it.  Multiple sheets "printed" to a
    PDF still result in a single PDF file.
    This has nothing to do with Eagle.  Panning and zooming a PDF is done with
    the PDF reader.
    single PDF image.
    the PDF reader.
