EAGLE User Support (English) Can you interconnect nets with different names?
  • Subscribers 187 subscribers
  • Views 442 views
  • different
  • interconnect
  • with
  • nets
  • names
urant
urant over 10 years ago
Hi!
I'm wondering if it's possible to inter-connect busses (nets) with different names?
This is what I'm trying to do:
I have a large uC that has different pins for analog, I/O and logic power. Each is connected to VCC, but with specific and different filter caps. For clarity, I want a bus named VDDD to go to it's filter caps and then connect to VCC, a VDDA that does the same, and so forth.
Everything is fine until I try to connect VDDD to VCC and all I can do is rename the new, merged net.
Any clues if it's possible to do?
Thank you
    On 14/01/16 00:13, Roy Alfaro wrote:
    Hi!
    different names?
    This is an FAQ. Most people use a library of virtual wire links -
    overlapping SMD pads - to connect different nets at one point only.
