EAGLE User Support (English) 30 day free trial only supports 2 layers?
  • Subscribers 189 subscribers
  • Views 1434 views
ed@ese.wustl.edu
ed@ese.wustl.edu over 10 years ago
I'm waiting for my company to issue a PO to buy the Standard Professional Educational version but I installed eagle 7.5 and used my Eagle Free Trial License code so I could get started on my 4 layer board design. On this page: EAGLE Free Trial has now ended it says that the Free 30-day trial is limited to 4 signal layers. But when I click on DRC in the PCB editor and add the other 2 layers (1*2*3*4), I get a dialog box saying :
"The layer setup contains layers 3,4, which are not available in the Freemium edition!"
Am I somehow using the wrong version?
Ed
    0 autodeskguest over 10 years ago in reply to ed@ese.wustl.edu
    On 01/28/2016 02:21 PM, Ed Richter wrote:
    Actually, it's (12+1516) for a 4 layer board with through vias.
    That depends on the board stack-up. The asterisk ("*") represent a core
    while the plus ("+") represents prepreg. One of the vendors I use
    normally builds their 4-layer boards with one core in the middle and
    prepreg on each side. This gives a stack-up of (12*1516).
    It doesn't matter much if you're doing vias that run through the entire
    stack, but it makes a lot of difference if you're trying to do buried
    and blind vias.
  • clem57
    0 clem57 over 10 years ago
    Here is the list of predefined layers at bottom EAGLE Help: LAYER
    Clem
  • ed@ese.wustl.edu
    0 ed@ese.wustl.edu over 10 years ago in reply to ed@ese.wustl.edu
    Actually, it's (1*2+15*16) for a 4 layer board with through vias.
  • ed@ese.wustl.edu
    Nevermind - you have to use layers 2 and 15 for the inner layers. That is (1*2*15*16) in the drc -> Layers dialog box
