EAGLE User Support (English) IPC-356A
  • Subscribers 178 subscribers
  • Views 1567 views
IPC-356A
zainka
zainka over 9 years ago
Hello
I have never done IPC-356A netlists before but now my boardhous requires one. However, the ulp that comes with Eagle generates an output that is way off in scale.
I see in the ulp that it uses the coordinates of an object and multiply it by "10/254" but the ulp is written in 2005. I remember there was a change in the grid resolution
in eagle when jumping for version7 (Or the coordinates system....), Atleast something changed that had influence on the excellon setup and we had to use EXCELLON24.
Cadsoft... How could I create correct ipc-356A netlist?
    0 autodeskguest over 9 years ago
    On 03.02.2016 13:54, vidar vidnes wrote:
    Hello
    way off in scale.
    Try this one.. This is what I use..
  • zainka
    0 zainka over 9 years ago in reply to autodeskguest
    eeeh? Nothing? I cant see any link or attachments.
    If its IPC-D-356.ulp version 2.0.2 it is the same as I have
    0 autodeskguest over 9 years ago in reply to zainka
    https://www.element14.com/community/message/173397
    element14 does not handle attachments from the news group or
    http://www.eaglecentral.ca/
    Look there for the attachment.
    Any "CadSoft Guest" on element14 is not using element14
    Paul R.
    In case you didnt find it on eaglecentral, here is the direct link (hope
    it works)
    http://www.eaglecentral.ca/index.php/mv/msg/52218/165029/0ac9bbb169e1fc237ad06127a630a5b5/#msg_165029
