EAGLE User Support (English) ULP filesize function caches values
  • Subscribers 189 subscribers
  • Views 967 views
Can anyone make filesize return the size of the file given as its parameter? There seems to be a bug that returns the size of the previous call if the file doesn't exist. Here is some sample code that demonstrates this on my machine (7.5.0).
// Simple ULP to show flaw in filesize function
void displayFileSize(string fileName)
  string fSize = "";  // Initialize to empty string (size == 1?)
  fSize[0] = '\0';    // Strings are zero terminated; erase this way too!
  sprintf(fSize, "%d", filesize(fileName));
  dlgMessageBox("displayFileSize: " + fileName + "\tSize: " + fSize + ".");
void main(void)
  // Verify that filesize can return '0' when file doesn't exist
  // Result: displayFileSize: file.txt Size: 0.
  displayFileSize("file.txt");
  // Write a string to a file so it exists and has non-zero size
  output("file.txt", "wt")
    printf("Here is some text to write.");
  // Verify that this new file has a valid size
  // Result: displayFileSize: file.txt Size: 27.
  // Demonstrate that a file that doesn't exist 'has the same size' as the last
  // file that filesize() processed.
  // Result: displayFileSize: f_a_k_e__F_i_l_e.txt Size: 27.
  displayFileSize("f_a_k_e__F_i_l_e.txt");
    0 autodeskguest over 10 years ago in reply to clem57
    On 2/4/2016 12:32 PM, Clem Martins wrote:
    Scratching head!:-/;\
    https://www.element14.com/community/message/173564
    Hi All,
    I've spoken to the developers, this is a confirmed bug. They are looking
    into a solution as we speak.
    hth,
    Jorge Garcia
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    Scratching head!imageimage
    0 e14 Contributor over 10 years ago in reply to clem57
    Thanks. That works inserted into my trivial example, but for my real code I need to call it a bunch, so I tried throwing the workaround into a function. The results are very interesting! During debugging I created two workaround functions identical other than their names. If I call the one defined first, it works. If I call the one defined second, the workaround doesn't work. Code:
    // Set to zero to fail, non-zero to function correctly
    int correct = 0;
      dlgMessageBox("displayFileSize: " + fileName + "\tSize: " + fSize + ".\n"
        + fileerror());
    void displayFileSize2(string fileName)
        + fileerror());
    // Create a zero byte file to get the size of
    void workAround(void)
      fileerror();
      output("null.txt", "wtD")
        printf("");
      if (fileerror())
        exit(1);
      if (correct)
        displayFileSize("null.txt");
      else
        displayFileSize2("null.txt");
        //filesize("null.txt"); // Call filesize to try & make last return value 0
      dlgMessageBox("Workaround finished.");
    void main(void)
      fileerror();
      output("file.txt", "wtD")
      // Try and clear 'cache'
      workAround();
  • clem57
    A work around output a null file.
    // Write a null string to a file so it exists and has zero size
    output("null.txt", "wt")
        printf("");
    Then you should get the correct results.
    Clem
