EAGLE User Support (English) No Vertical Flip Option
  • Subscribers 189 subscribers
  • Views 2629 views
COMPACT
COMPACT over 10 years ago
Hi Jorge,
Is there a vertical flip function available for components?
Have a nice day
Compact
  • jmcc99
    0 jmcc99 over 9 years ago in reply to COMPACT
    Old thread but for those googling...
    You could setup a script to make it one step and make the script a keyboard shortcut.
    Josh
    0 autodeskguest over 10 years ago in reply to COMPACT
    On 2/8/2016 7:45 PM, COMPACT wrote:
    BTW - when flipping a component I'm annoyed by the way the annotations
    are moved.
    I have to smash the component and move them.
    Is it worthwhile to enhance EAGLE to nominate locked position
    annotations.
    https://www.element14.com/community/message/173916
    Hi Compact,
    There isn't a one click way to do a vertical flip, you have to rotate to
    the appropriate orientation and then mirror.
    Someone else has already asked for some mechanism to basically avoid
    having to smash parts as often.
    hth,
    Jorge Garcia
  • COMPACT
    0 COMPACT over 10 years ago in reply to COMPACT
    BTW - when flipping a component I'm annoyed by the way the annotations are moved.
    Is it worthwhile to enhance EAGLE to nominate locked position annotations.
  • COMPACT
    0 COMPACT over 10 years ago in reply to autodeskguest
    ,egroJ iH
    It's with regards to the schematic capture. And that's what I've been doing.
    I would like to perform a vertical flip in a single action as per the horizontal flip.
    sdrageR
    tcapmoC
    On 2/8/2016 4:32 PM, COMPACT wrote:
    Hi Jorge,
    Have a nice day
    Compact
    https://www.element14.com/community/message/173905
    Hi Compact,
    I hope you're doing well. Define vertical flip.
    If you are referring to the schematic, you can usually obtain any type
    of component configuration by using the rotate and mirror operations.
    If you are talking about the board then usually, the mirror command can
    take components to the bottom of the board.
    Best Regards,
    Jorge Garcia
