EAGLE User Support (English) How to add through-hole pads within polygon pads in package editor?
  • Views 296 views
  • through-hole
  • polygon
How do I properly add through-hole pads within a polygon pad in the package editor and device editor?
This is what I have tried:  In the package editor, I have created a polygon pad on the top layer.  I have added many through-hole pads within the polygon pad.  In the device editor, I connect/append all of the through-hole pads to a schematic pin called "GND".  Then, I add the part to my schematic and generate the board file.  The problem is that when I open the board file in the layout editor, there is a complicated ratsnest between all the through-hole pads.  This confuses me because these pads should already be connected electrically.  Why is there a ratsnest?
What is the proper way to do this?
  • clem57
    0 clem57 over 10 years ago
    I would create a electric ground across the area of the polygon or manual route the connection instead of autoroute.
