EAGLE User Support (English) Generate a wirelist
  • Subscribers 189 subscribers
  • Views 640 views
Generate a wirelist
dksmall
dksmall over 10 years ago
Is it possible to generate a wirelist for my eagle designs?  The PCB will still be copper, but I need the final pinout of the 128-pin connectors, so the cables can be documented.  A wirelist or similar would help to document that cable.
  • dksmall
    0 dksmall over 10 years ago in reply to rachaelp
    Looks like this will work, thanks!
  • rachaelp
    0 rachaelp over 10 years ago
    You can export a netlist from the schematic or board via the File -> Export -> Netlist option. However, I think from what you are describing it would be better to export a pinlist via the File -> Export -> Pinlist option. You can then open the generated file and scroll down to where your 128-pin connectors are listed and you'll find a list of all the pins and their associated nets all nicely grouped together.
    Best Regards,
    Rachael
