EAGLE User Support (English) Is there a way to force a single polygon to process?
  • Subscribers 189 subscribers
  • Views 722 views
bbartley
bbartley over 10 years ago
In 6.5.0, ideally.
I assume this must have been asked, but I couldn't find it.
If not, can this constitute a feature request?
BB
  • rachaelp
    0 rachaelp over 10 years ago in reply to bbartley
    You're welcome. I've just looked and this is mentioned as a bug fix in the 7.0.0 release notes so I think they intended it to work that way previously but somehow they messed it up or broke it!
  • bbartley
    0 bbartley over 10 years ago in reply to rachaelp
    Argh. In 6.5.0 the Ratsnest item is in that contextual menu, but it appears to do an overall Ratsnest, and not just process the one polygon.
    Not worth upgrading for, but I might think differently in the midst of the irritation.
    Thanks for checking!
    BB
  • rachaelp
    I'd never even tried before I saw this question and my initial reaction was to say no but then I went and checked and you actually can. All you do is right click on the polygon you wish to process to select it and get up the associated context menu and then click on Ratsnest and that single polygon is processed. I'm using 7.5.0 and don't have access to anything earlier so I don't know if this was also the case in 6.5.0.
    Best Regards,
    Rachael
