EAGLE User Support (English) Renaming module port disconnects route?
  • Subscribers 189 subscribers
  • Views 743 views
  • port
  • renaming
  • hierarchy
vitomarolda70
vitomarolda70 over 10 years ago
I would like to rename a module port in an already-routed board.
In any way I do that, the pcb track is deleted.
I have tried so far:
  • Using command NAME on the net in the module schematic:
    • the name changes in the module schematic
    • the name does not change in the port name in top schematic
    • the pcb route is deleted.
  • Using command INFO Ctrl-left click on the module port, in the TOP schematic.:
    • the name changes in the port name of all module instances, in top schematic
    • the name does not change in the module schematic.
  • Using command INFO Ctrl-left click on the module port, in the MODULE schematic:
    • this does not delete the track
    • successfully renames the net in the module schematic
    • BUT it does not update the port name in the module ports of module instances in TOP schematic.
Someone can help?
Thank you in advance
--Vito
  • vitomarolda70
    0 vitomarolda70 over 10 years ago in reply to clem57
    Thank you Clem,
    I've done manual file editing before (had load errors after some copy command, I think between top schematics and module, but I am not sure).
    I think I can do that.
    In order to have it fixed, should I submit a bug?
    --Vito.
  • clem57
    0 clem57 over 10 years ago
    Unfortunately the name is key to the underlying structure. By renaming it the database would have to change. If you are not moving things, I believe you can export the design and carefully change the name in the file and re-import. But save a good copy just in case it fails.
    Clem
