EAGLE User Support (English) Looking for a certain 4-pin connector and cable [with photos]
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 717 views
  • connector
  • 4-pin
Good day! I'm looking for a certain 4-pin connector. It looks like the photos below.
Does anyone have an idea what it is? Thank you.
  • uscdadnyc
    0 uscdadnyc over 10 years ago
    Try some old 5.25"  or 2.5" Floppy Disk drives. The Motherboard(s) on these old devices had/has similar Connectors. Try a Thrift Shop (in USA) or second-hand Store (Else-where)
    USCDADNYC (NY NY USA)
    0 shabaz over 10 years ago in reply to e14 Contributor
    Hi Renz,
    Unfortunately I've never seen a female-to-female pre-built cable for this particular connector, although like you, I've needed it once.
    What I did was just purchase two, and solder the wires together and heat shrink around each wire. Not optimal, but it may be the
    easiest quick solution.
    You'll need very small diameter heat shrink sleeving (available from Farnell/Newark).
    0 e14 Contributor over 10 years ago in reply to shabaz
    Thanks for the reply shabaz image A JST SH connector seems to be right on the mark. Are there any female-female cables available for this connector? Can't seem to find one online. Here's one from Sparkfun, but no termination at the end.
    https://www.sparkfun.com/products/10359
    I need to be able to connect two boards, with the one board being in this picture. I could drill pads and solder the other end to the other board using the Sparkfun cable, but I'm looking to have the connection removable.
    Pictures are fuzzy, and no dimensions.
    Looks like JST 'SH', but if you measure the pitch precisely you'll be able to compare what you've got with the mechanical drawings for the 'SH'
    range on the JST website, and google for photos of 'JST SH' to see if the images match with what you have got.
    Otherwise, once you have the pitch, search the JST and Molex websites (they are a couple of popular connector manufacturers) and see if any product lines with that pitch have drawings and measurements that match what you have got.
