EAGLE User Support (English) Text on bottom layer shows up on preview but not on printout.
  • Subscribers 187 subscribers
  • Views 184 views
JanH
JanH over 10 years ago
When I print the bottom layer on foil every thing shows up perfectly except the text.
I placed some text on the bottom layer so this text will show up as copper when the board is etched.
I see the text on the preview but not on the printout.
There are some faint lines where the text should be.
I do this all the time on the top layer without any problems.
When I change this text to "Top layer" then it prints OK.
Is it for some reason impossible to put text on the bottom layer in 7.50?
I seem to remember that in older versions it was possible to put text on bottom layer.
I seldom use bottom layer for text because I like text to be still readable when board in installed, so I am not sure.
I am using Eagle 7.50
Best regards, Jan H.
