EAGLE User Support (English) Standard Edition Size Limit Problem
  • Subscribers 189 subscribers
  • Views 451 views
I just purchased Eagle (standard maker edition), and am running into an odd problem.
I opened up an Eagle file for the Adafruit PCA9685 board. When I check the dimensions within the editor, the board is about 63x25 mm. Which should easily be within the max size limit for the standard edition.
Yet when I try to move objects on the left half of the board I get an error that the standard edition doesn't let me make the change because the part would be outside the allowed limits. Yet the entire board is smaller than the limit.
I can move stuff around on the right hand half of the board.
Any idea what's going on?
- Mark
    0 e14 Contributor over 10 years ago in reply to clem57
    Thanx! After spending much time on the problem I thought it might be the issue, but I wasn't sure how to move the entire board. I'm still getting used to the syntax/ethos of Eagle.
    - Mark
  • clem57
    0 clem57 over 10 years ago
    pcb - Eagle board editor not allowing me to place components outside area which is permitted - Electrical Engineering St…
         As described above, the board is positioned to the top left corner. That means the right is where the free space lies.
    Clem
