EAGLE User Support (English) Best way to make pads for 2mm through hole toggle
  • Views 309 views
mrdouble
mrdouble over 10 years ago
Man, eagle has got me stumped. I have successfully used eagle to make several homebrew (toner transfer) boards but this i has got me whooped.
I need to mount couple of  miniature toggles with blade dimensions of 1mm x 2mm (height is irrelevant).
I have been been doing some serious googling and come up with all kinds of answeres as to how to make slotted pads but none of them work. Some of the answers suggest that its impossible to do due to the fact board houses dont mill slots. I find this very hard to believe as tons of components have slots (switches, plugs, displays)
I have already played around and drilled out slots by hand and it worked out great but I need need a pattern to keep all 10 strait and aligned. If I can just get an idea on the direction to go would be great
thanks I advance
Micheal
  • clem57
    0 clem57 over 10 years ago
    You can use the "docu" layer to mark the proper place for holes and a square to mark locations of the parts. This will show alignment with the parts before you send.
    Clem
