EAGLE User Support (English) Eagle 7.5 will not run after a few times without a reinstall -- help
  • Replies 8 replies
  • Views 1654 views
boylansr
boylansr over 10 years ago
I installed Eagle 7.5 on a Windows 10 laptop. I use it a few times. I go to use it again but it does not run. I uninstall it and clean the register with regedit and reinstall it. I run eagle a few more times then have to repeat the above. Anyone know how to break this cycle?
  • boylansr
    0 boylansr over 10 years ago in reply to autodeskguest
    CadSoft Guest wrote:
    Am 23.04.2016 um 07:37 schrieb boylansr:
    I have the Make Personal license.
    https://www.element14.com/community/message/195248
    could you please give us a bit more information?
    Do you always login to Windows as the same user?
    In which directory is EAGLE installed?
    If you reboot and want to restart EAGLE what is the EAGLE error message?
    Could you please check if in the EAGLE-7.x.x/bin folder is a file
    named eagle.key? Is it still there when EAGLE refuses to start?
    Richard Hammerl
    1. Yes I always login as the same user.
    2. C:\EAGLE-7.5.0 is the install directory.
    3. There is no error message it just does not start (the mouse pointer shows busy for a few second).
    4. Yes the eagle.key file is still there.
    5. So far Eagle 7.5.3 beta is working three days without a problem. I have never had a problem with versions 4.0-7.4. Eagle 7.5 showed no problems while it was running, it only had the problem of me closing the program and then not running the next time I try to start it again. If I reinstall it without removing any entries in the registry same problem, but if I clean up the registry and reinstall it will work for awhile. I assume the problem happens at closing the program down and evolves the registry.
    0 autodeskguest over 10 years ago in reply to boylansr
    Richard Hammerl
    Richard Hammerl
    Richard Hammerl
  • boylansr
    Am 22.04.2016 um 20:23 schrieb boylansr:
    https://www.element14.com/community/message/195245
    You should tell which kind of  eagle license you have.
    Joern Paschedag
    Joern Paschedag
    Joern Paschedag
