EAGLE User Support (English) Multiple part, multiple footprint component library solution
  • Subscribers 187 subscribers
  • Views 201 views
I have to build an Eagle library entry for a 20 SPST relay board that connects to PCB with wire-to-PCB connectors. I have created a component with 20 "gates" - relays that can now be placed anyway designed wants in a schematic. I can't find a usable solution for PCB side. I want to have 4 to 12 pin connectors that could be placed freely on the PCB because not always all relays are used or wire must be scattered on PCB. For now I work-around by creating a custom footprint for every project, but it lakes long and requires iterations through multiple files. What should be the most appropriate way of dealing with such device using Eagle?
