EAGLE User Support (English) Is it possible to copy and paste to a different layer ?
  • Subscribers 189 subscribers
  • Views 1363 views
I was hoping to find a quick way in my ULP code to copy items from layer 21 or 22 (tPlace, bPlace) to a different layer.
But the code snippet below will only paste onto the layer it copied from i.e. layer 21, where it appears as a duplicate item.
I have tried CUT instead of COPY.
I was hoping it would paste to e.g. layer 47 (or any other layer), where it should show as green, but it doesn't work. It only pastes back onto layer 21.
I am unsure if I have missed a command, or whether it's simply impossible.
Thanks for any clues,
Bob.
#usage " copy & paste test ";
//   Problem: it doesn't want to paste onto a different layer, only pastes
//                  onto the original layer it copied from
//   Q. How to copy and paste onto a different layer ?
//      put some wires or polygon shape onto layer 21
string s = "";
s = "DISPLAY 21;"; "\n";
s = s + "GROUP ALL;"; "\n";
s = s + "COPY;"; "\n";
s = s + "LAYER 47;"; "\n";
s = s + "PASTE;"; "\n";
s = s + "DISPLAY 21 47;"; "\n";
exit(s);
    0 e14 Contributor over 10 years ago in reply to Nate1616
    I have been looking at the code on that link. Seems to iterate over the different elements/items on a layer etc and recreate them on a new layer. No conclusion yet, if that would be an alternative solution. Just trying a few more experiments - nothing to report. And, well, I did discover that my original question isn't that simple - e.g. there seems to be some items on tPlace or bPlace that can't be copied anyway - not sure if it's because they are locked, or some other reason. This question can probably fade away .....
    Bob.
  • Nate1616
    0 Nate1616 over 10 years ago
    Bob-
    Try this ULP from Eagle's github  https://github.com/plusea/EAGLE/blob/master/ulp/copy-layer-to-any-layer.ulp
    Nate
