EAGLE User Support (English) Library Component
  • Subscribers 189 subscribers
  • Views 582 views
Library Component
I've just spent as LONG time making a new library component, but when i add it to the schematic, then try to move it into my board,
it drags OK, but I get an error msg "The standard edition of eagle can't perform the requested action. Some objects extend outside the allowed board area"
But it is NOT outside the board area. I have many other components on the board, and my board margins are correct.  Its obviously a problem with my component (An Attend micro SD connector type 1121-TXAR-R, which  i cant find anywhere else).
I don't want to go through the pain of re-making the component, because frankly - its not easy or  intuitive - its a pain in in the ****.
Any ideas would be appreciated, as this has bought me to a complete standstill.
  • rachaelp
    0 rachaelp over 10 years ago in reply to e14 Contributor
    Hi Neil,
    That's great, glad I could help :-)
    Best Regards,
    Rachael
    Thankyou Rachael ..that was it exactly - a small peice of rogue track. Now fixed.
    0 e14 Contributor over 10 years ago in reply to rachaelp
    aha...that sounds like a good start. i will do that anc get back to the group.
    neil
  • rachaelp
    Hi Neil,
    In the library editor if you open up the footprint and turn all the layers on the press zoom to fit, does it then zoom out to show something else in your part you didn't realise was there?
    Best Regards,
    Rachael
