EAGLE User Support (English) Pads are different in Package Editor and in PCB Editor
  • Subscribers 189 subscribers
  • Views 659 views
ed@ese.wustl.edu
ed@ese.wustl.edu over 10 years ago
I'm creating a package for the Global Connector Technologies BC020 header (http://www.farnell.com/datasheets/682675.pdf ). The pads look different in the Package Editor than when I instantiate the device in the PCB (see attached screenshots). I'm getting a DRC error in the PCB editor because the pads are way bigger than what I want. Any ideas?
imagePadsLayerDifferenceInPackage_PCB.pdf
  • rachaelp
    0 rachaelp over 10 years ago in reply to ed@ese.wustl.edu
    Hi Ed,
    Yes it's Restring as you have found out! I'm glad you have got it sorted out :-)
    Best Regards,
    Rachael
  • ed@ese.wustl.edu
    0 ed@ese.wustl.edu over 10 years ago in reply to ed@ese.wustl.edu
    Thanks - it was the Rest Ring (Restring) settings in DRC that was overriding my pad settings in the library (EAGLE  -- What are the Restring Settings in the Design Rules for? )
    Ed
  • ed@ese.wustl.edu
    0 ed@ese.wustl.edu over 10 years ago in reply to rachaelp
    Hi Racheal,
    Thanks for responding. Do you know which DRC settings? I have 7 mil of margin on the pad to pad clearance (last picture in the attahment).
    Ed
  • rachaelp
    Hi Ed,
    It could be down to your DRC settings. Unlike other ECAD packages, in EAGLE the DRC settings can actually affect the board as it enforces some minimum sizes.
    Best Regards,
    Rachael
