EAGLE User Support (English) How do i create holes based on a DXF i have imported WITHOUT redrawing the polygons
  • Views 1017 views
  • eagle
  • dxf
  • holes
  • cad
  • polygons
  • cnc.
shearder
shearder over 10 years ago
I have designed a panel from acrylic. It has switches, buttons, LEDs a LCD screen and back lighting. I saved the panel and then imported to brd as a dxf and use it in dimension layer for board outline etc. I need to cut out a number of holes based on the "holes" in the cad and some circles are NOT holes BUT LED positions. How do i create holes that must be cut out without drawing new polygons and trying to align to the DXF which i imported?
I hope that made sense. I need to be able to select a circle/hole and then create a hole to be cutout. Also i need to use some circles and positions for LEDs.
Thanks in advance
  • rachaelp
    0 rachaelp over 10 years ago in reply to autodeskguest
    Hi Lorenz, yep that's a good point. I'm still learning ULP at the moment so sometimes I still do things the long way where there is something much more obvious! :-)
    0 autodeskguest over 10 years ago in reply to rachaelp
    rachaelp wrote:
    I thought this was an interesting query so decided to write a ULP to do this. Save the below as circleToHole.ulp.
    sprintf(cmd, "GRID mil; HOLE %f (%f %f);", 2.0 * u2mil(C.radius), u2mil(C.x), u2mil(C.y));
    you don't need to mess with the grid settings, just force the unit for
    the values:
    sprintf(cmd, "HOLE %fmil (%fmil %fmil);", 2.0 * u2mil(C.radius), u2mil(C.x), u2mil(C.y));
         Lorenz
  • rachaelp
    Moved to reply in your thread in the support forum.
    Thanks in advance
    https://www.element14.com/community/message/197958
    Hi Sean
    This forum (eagle.suggest.eng) is for making suggestions for changes to
    the EagleCad Software.
    Please use the support (eagle.support.eng) or the user chat
    (eagle.userchat.eng) forums for posts of your nature.
    HTH
    Warren
    Thanks in advance
    Hi Sean
    HTH
    Warren
