EAGLE User Support (English) How do I create holes and positions from imported DXF
  • Replies 21 replies
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 5012 views
  • cnc
  • holes
  • eagle pcb
  • led
  • layer
  • polygon
shearder
shearder over 10 years ago
Hi All
I have a panel that i have designed which has switches, buttons, knobs (rotaries), LEDs and a LCD screen. I have imported the DXF version of this into Eagle on the dimension layer. I will machine a 300mmx300mm Double sided board.
What i want to know: Some circles on the DXF are HOLES some are positions for LEDs.
How do i go about selecting a circle and making it a HOLE without redrawing a polygon and TRYING to align it. Also, how do i move other circles to a different layer for positioning of the LEDs?
Hope that makes sense.
Thanks in advance.
    Am 27.05.2016 um 06:54 schrieb Sean Hearder:
    Hi All
    Thanks in advance.
    to move a circle to a other layer:
    ex. tPlace
    Change-> Layer-> tPlace
    then click on the circles witch do want to move.
    Maybe you can "move" the holes/circles to the Holeslayer(45)
    or
    Make a new Layer (display) "Helper" (color mybe a ugglyone like purple)
    move the holes-cricles to this layer.
    then place holes with the drill that you want (hole 3.2mm)
    near by the holescircles.
    With the "info" you can get the coords of the circle.
    now "info" the hole and type in the coords of the circle.
    (the hole move to circle)
    If you done with all "holes" you can delete the helper layer
    (the Helperlayer will be needfull.
    1. so you have a Layer with the holes-cricles and they of
       your import layer.
    2. you can check with circles do you move to holes.
    I hope i explained it unterstandfull (english is
      not my native-language)
    HTH
    Werner
