EAGLE User Support (English) Lines shown in ratsnest but not autorouting
  • Views 484 views
First up, I ma very much a newbie to using EagleCad
I have a fairly simple schematic using an arduino nano from the Element14 library connecting to 2 motor drivers
All the connections show on the board as part of the ratsnest but when I autoroute none of the traces to the nano are drawn.
I have spent several hours trying to figure what I am doing wrong.
I have attached the .sch and .brd files
Thanks in advance for any advice
Regards
Colin
driver-v1.0.zip
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    Thank You very much for you help. it is appreciated
    Cheers
    COlin
    Regards
    Colin
    https://www.element14.com/community/message/198549
    driver-v1.0.zip
    Hi Colin
    You have a few issues:
    (1) The capacitor in the top right of the schematic is not connected to
    the nets. It also does not appear on the schematic for some reason so I
    would delete it and add it again.
    While you are just beginning, it pays to check connections to pins by
    moving the schematic symbol and verifying the nets stay attached. Just
    hit 'Esc' to have the moved item snap back to its starting position.
    Remember to use 'NET' and not 'WIRE' when connecting pins on  the schematic
    (2) The routing issue is caused by the outline of the nano being on the
    layer 20Dimension. The router is seeing it as the edge of the board and
    won't route beyond it.
    You could change the layer of teh outline to, say, tPlace. Then the
    router will work
    (3) I suspect your nano element is not what you need. If you are going
    to plug a nano into the PCB you are making then you don't need a nano
    template, rather,just the headers it will plug into. You could find or
    make a nano element (footprint) that consists of the header pads, tPlace
    silkscreen outline and wording. It could have holes if the nano board is
    to be screwed down.
    HTH
    Warren
