EAGLE User Support (English) Methods of Viewing Nets
  • Replies 18 replies
  • Subscribers 192 subscribers
  • Views 1999 views
I have been using Eagle for a few months now after previously using Pads and the biggest drawback seems to be the inability to color code the nets.  This makes intelligent component placement and the drawing of pour areas a lot more tedious than those operations need to be.  I did read the tip about using the RATSNEST command to hide/show certain nets and that helps somewhat prior to routing.   But for drawing the pour areas which I normally do after routing, I have resorted to sticking pieces of tape to the computer screen while the SHOW command highlights the net of interest to mark the boundaries of where I want to draw the pour.  Or course once I begin drawing the pour the highlighted net disappears but the little pieces of tape remain and I can draw the pour using the pieces of tape as a guide.  I would just like to know if there is a more sensible way to do this in Eagle.
  • rachaelp
    0 rachaelp over 10 years ago in reply to e14candies
    I agree, this is something that needs fixing in EAGLE. It's been raised several times before (including by myself) and from what I can gather it is at least on Cadsoft's radar so hopefully this will end up resolved in some future version.....
  • e14candies
    0 e14candies over 10 years ago
    Why not simply fix Eagle so the Show command works as needed? Clicking on
    anything after "showing" makes it go away, severely limiting its use. May
    be use a shift-click to "lock" it.
    Also, there should be an option to have a highlighter (as though you took a
    highlighter to a schematic or board layout)--when you are zoomed out (such
    as trying to view a net in a large schematic), it is hard to see the very
    thin lines even when they are colored/shown.
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    The file, copy-layer-to any-layer.ulp, was not in my installation nor on the cadsoftusa web site.  It did find the text of the .ulp online and created a file for it.  This produced version 1.5 of the .ulp.  It just asks me to select a valid layer, no matter what layer I choose.  I don't know what it takes to make a layer valid.  It appears that this .ulp is going to copy wires and/or polygons.  In my usage, the polygon has not yet been created and some of the pads of interest in the net will not have any wires so I'm not sure how much help this is going to be.
    0 autodeskguest over 10 years ago in reply to autodeskguest
    It seems the ulp copy-layer-to any-layer.ulp could be useful here.
    Create a user defined layer
    Run the ulp copying the net from the top to the new user defined layer.
    Run the ulp copying the net from the bottom to the user defined layer.
    To delete,  display only the user defined layer and type into the command
    line
    Group all; delete (>0 0)
    or you could use the mouse
    HTH
    Warren
    Rob Pearce wrote on Fri, 08 July 2016 08:57
    On 07/07/16 20:41, warrenbrayshaw wrote:
    Create a user defined layer and place construction lines in that
    layer
    to guide your placement of polygon outlines. You will still have
    the
    issue with disappearing shown items though as you create the
    construction lines.
    I'm not quite sure how that fixes anything. The OP's problem is that,
    while he can highlight the net he's interested in, the moment he
    starts
    to trace around it the highlighting disappears. Use of any tool
    switches
    off the "show". So he can't trace it.
    The idea is to negate the need for "sticking pieces of tape to the computer
    screen"
    I did comment that there was still an issue with loosing the highlighted
    /shown nets.
    Create a user defined layer and place construction lines in that layer
    to guide your placement of polygon outlines. You will still have the
    construction lines.
    while he can highlight the net he's interested in, the moment he starts
    to trace around it the highlighting disappears. Use of any tool switches
    One thought that occurred to me just now - do a "show" to get the
    highlight, then use a screen capture tool to capture an image. Place
    this on an image viewer alongside the Eagle window as a guide. You
    should be able to draw the polygon outline by reference to the patterns
    of pads and vias around the highlight on the image.
    But I'd still definitely vote for a "persistent" option to make the
    highlight remain until the next use of SHOW (or possibly some few other
    tools like RATSNEST)
    On 8/07/2016 4:16 a.m., Tom Penick wrote:
    I have been using Eagle for a few months now after previously using Pads and the biggest drawback seems to be the inability to color code the nets.  This makes intelligent component placement and the drawing of pour areas a lot more tedious than those operations need to be.  I did read the tip about using the RATSNEST command to hide/show certain nets and that helps somewhat prior to routing.   But for drawing the pour areas which I normally do after routing, I have resorted to sticking pieces of tape to the computer screen while the SHOW command is highlights the net of interest to mark the boundaries of where I want to draw the pour.  Or course once I begin drawing the pour the highlighted net disappears but the little pieces of tape remain and I can draw the pour using the pieces of tape as a guide.  I would just like to know if there is a more sensible way to do this in Eagle.
    Hi
    To do away with sticking tape on your monitor.
    construction lines.
    HTH
    Warren
    I had exactly that same frustration just recently. There doesn't seem to
    be an easy option but I do recall "sticky highlighting" being discussed.
    Probably still a suggestion and not implemented yet, unfortunately.
