EAGLE User Support (English) Methods of Viewing Nets
  • Replies 18 replies
  • Subscribers 192 subscribers
  • Views 1998 views
I have been using Eagle for a few months now after previously using Pads and the biggest drawback seems to be the inability to color code the nets.  This makes intelligent component placement and the drawing of pour areas a lot more tedious than those operations need to be.  I did read the tip about using the RATSNEST command to hide/show certain nets and that helps somewhat prior to routing.   But for drawing the pour areas which I normally do after routing, I have resorted to sticking pieces of tape to the computer screen while the SHOW command highlights the net of interest to mark the boundaries of where I want to draw the pour.  Or course once I begin drawing the pour the highlighted net disappears but the little pieces of tape remain and I can draw the pour using the pieces of tape as a guide.  I would just like to know if there is a more sensible way to do this in Eagle.
  • rachaelp
    0 rachaelp over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote:
    Now the different colors for different nets or netclasses thing is more
    difficult because currently in EAGLE colors are only dictated by layers
    so the I think adding something like that would require some more
    fundamental changes in EAGLE.
    Most ECAD tools I have used assign colour initially using layers. This can then be overridden for individual nets or using net class properties. I can't see a clean way of doing this without colour and it's a really useful feature.
    I agree the persistent highlight is higher priority, this isn't too far down the list for me though :-)
    Best Regards,
    Rachael
  • dukepro
    0 dukepro over 10 years ago in reply to autodeskguest
    On 07/16/2016 04:27 AM, Joern Paschedag wrote:
    Am 16.07.2016 um 09:38 schrieb Guillaume barrey:
    I agree too. The 'SHOW' command need some enhancement, and the big
    first one would be that one (persistent highlight). This is really
    annoying, and I may be wrong, but I think that a lot of users would
    be glad to have it !
    Guillaume.
    https://www.element14.com/community/message/201531
    Count me in.
    Here, here.  I'm in for this as well.  Borrowing from display...
        show D0 D1;    // highlights two nets
        show +D2;        // Adds D2 to the list of highlighted objects
        show +IC1;        // adds a component to the list.
        show -D1;        // un-highlights D1
        show none D7 D6 D5;    // only D5-D7 are highlighted
        show last;        // Back to what it was before - D0 D2 and IC1.
    Perhaps even some show aliases:
        show = databus none D7 D6 D5 D4 D3 D2 D1;
        show = addrbus none A2 A1 A0;
        show none IRQ0 IRQ1 NMI;
        show = ctlbus @;
    Just take the cli for display and adapt it to show.
    I know... I'm minimizing the work involved.  But it's an approach worth
    considering.
    Enjoy,
        - Chuck
    73480.att1.html.zip
    0 autodeskguest over 10 years ago in reply to rachaelp
    On 7/9/2016 4:21 PM, rachaelp wrote:
    I agree, this is something that needs fixing in EAGLE. It's been raised several times before (including by myself) and from what I can gather it is at least on Cadsoft's radar so hopefully this will end up resolved in some future version.....
    https://www.element14.com/community/message/201141
    Hi All,
    Persistent show is on the radar and I think that one is probably
    relatively easy to implement(I'm not a developer, so don't quote me on
    that).
    I think we can distill that request to needing some way to separate and
    organize nets(netclasses) visually.Maybe there is a way other than color
    to do this? Just a thought.
    Best Regards,
    Jorge Garcia
    Am 16.07.2016 um 10:57 schrieb rachaelp:
    Among others I suggested to make it flash because in today's plenty of layers, signal colours are hardly to distinguish even if they are high lighted.
    Yes you are right, it can be hard to distinguish at times. I think a related feature which I have mentioned previously is to allow different colours to be assigned to different net classes. This combined with a persistent highlight and a larger default colour palette should make a big difference. I do kinda like the idea of having the ability to temporarily make a highlighted net flash to accentuate the highlight, I can see that being quite helpful at times.
    It might be that cadsoft has it on Radar but imho the Show command seams to be in stealth mode image
    They would obviously benefit from having a persistent highlight on their todo list as well image
    Best Regards,
    Rachael
    https://www.element14.com/community/message/201564
    Bulls Eye image
    Joern Paschedag
    Best Regards,
    Rachael
    Direct Hit image
    Joern Paschedag
  • rachaelp
    Best Regards,
    Rachael
    0 autodeskguest over 10 years ago in reply to kikoun
    I agree too. The 'SHOW' command need some enhancement, and the big first one would be that one (persistent highlight). This is really annoying, and I may be wrong, but I think that a lot of users would be glad to have it !
    Guillaume.
    Count me in.
    Joern Paschedag
    Am 09.07.2016 um 22:21 schrieb rachaelp:
    I think this wish is about as half as old as eagle itself.
    lighted.
    Joern Paschedag
  • kikoun
    0 kikoun over 10 years ago in reply to rachaelp
    Guillaume.
  • e14candies
    0 e14candies over 10 years ago
    Cadsoft invested in a large echo chamber several years ago
         ...so hopefully this will end up resolved in some future version...
    version...
                      ...end up resolved in some future version...
                          ...future version...
