EAGLE User Support (English) Creating library from board?
  • Subscribers 187 subscribers
  • Views 2148 views
btmcmahan
btmcmahan over 10 years ago
I have a small board created from about 5 smd parts.  How can I take that board & create a library from it, so I can insert that board into other projects.
simple example, lets say I have a board consisting of a LM7805 voltage regulator + two capacitors.  I want to create a part so I can insert all three parts at once.
  • geralds
    0 geralds over 10 years ago in reply to autodeskguest
    https://www.element14.com/community/message/201827
    ?? this link goes back to this thread.
    The attachment - exp-lbrs.ulp is just a plain text, not a file.
    Regards
    Gerald
    0 autodeskguest over 10 years ago in reply to autodeskguest
    On 20/07/16 06:27, Joern Paschedag wrote:
    Am 20.07.2016 um 01:23 schrieb Brandon McMahan:
    other projects.
    exp-lbrs.ulp
    Surely that's exactly NOT what the OP asked for. What he did ask for
    can't be done... and shouldn't be done the way he phrased it, although a
    method of doing very-nearly-that-but-not would be a useful addition.
    What he's after is a sub-module, whereby a small section of circuit can
    be designed, both on schematic and board, and saved as an entity. Later,
    this can be incorporated into a future design. When doing so, the
    components and their nets are all imported into the schematic, including
    geometric layout, appropriately renumbered to avoid clashes. At the same
    time, the packages and copper are imported into the board, and defined
    as a group for easy selection and placement.
  • geralds
    exporting a lib from sch or pcb is very easy:
    for you..  in the pcb program:
    Menu: Files -> Exporting -> Library >> than 3 questions are for you, for what you need... than press ok
    Gerald
    exp-lbrs.ulp
    Joern Paschedag
