EAGLE User Support (English) global part substitution
  • Views 721 views
davedr
davedr over 10 years ago
I am new to Eagle. I've recently purchased it because I may work on my own and can't afford Altium, which is what I use at work now. I would like to substitute, for example, the us version resistor schematic symbol for the european boxy resistor. Is there a way to do this in Eagle without doing a one by one substitution.
Thanks in advance.
Dave R.
    0 autodeskguest over 10 years ago in reply to rachaelp
    Am 15.08.2016 um 10:42 schrieb rachaelp:
    CadSoft Guest wrote:
    Hi Jorge, imho one can replace only within a library, not across libraries.
    That means Dave cannot "reach" from the eu-library to the us-library.
    So one could of course merge both libraries together, or use the method
    James Morrison suggested using a text editor ... with care
    Joern Paschedag
    I'm not sure you are right there, when I start the replace command it pops up the library browser and you can choose a component from any library currently in use. I just tried this out and swapped a resistor out for a diode from a different library without issue. Obviously it has to have the same number of pins and they need naming the same but this shouldn't be an issue across the two resistor packages.
    Best Regards,
    Rachael
    https://www.element14.com/community/message/203673
    Ouuups you  are right Rachael. Old man mixed up apples with pears or,
    for the non farmers,
    "change package" with "replace" image
    Joern Paschedag
  • rachaelp
    0 rachaelp over 10 years ago in reply to autodeskguest
    Joern Paschedag
    Best Regards,
    Rachael
    0 autodeskguest over 10 years ago in reply to autodeskguest
    Am 10.08.2016 um 21:47 schrieb Jorge Garcia:
    Thanks in advance.
    Dave R.
    https://www.element14.com/community/message/203499
    Hi Dave,
    I hope you're doing well. Unfortunately, the best solution is to use the
    REPLACE command which is a one by one sub. However, keep in mind the the
    verb-noun paradigm in EAGLE makes this a less tiresome proposition.
    All you have to do is click the REPLACE icon, select the boxy resistor
    from the rcl library and click OK. Now just left click once on each
    resistor to change it.
    You'll find it's much faster then having to right click on each resistor
    and selecting replace.
    hth,
    Jorge Garcia
    James Morrison suggested using a text editor ... with care image
    Joern Paschedag
    Jorge Garcia wrote on Wed, 10 August 2016 19:47
    Thanks in advance.
    Dave R.
    Hi Dave,
    the
    the
    resistor
    Jorge, can't you do a search and replace on the XML file using a text
    editor?  If the symbol is the same and the name just changed I think this
    is easiest.  Of course you can really mess up the file doing this so make
    sure to make a backup copy first.
    I use this when I need to change the library reference of a symbol so that
    updating from library will work (if the original library no longer exists,
    which still should create a warning and doesn't).
    James.
    Order your EAGLE license from Stratford Digital at
    http://www.eaglelicenses.com
    Thanks in advance.
    Dave R.
    Hi Dave,
    hth,
    Jorge Garcia
