EAGLE User Support (English) Eagle Arduino Library
  • Subscribers 189 subscribers
  • Views 1509 views
ab9a
ab9a over 10 years ago
I am using the E14_Arduino_revC.lbr.
The Arduino Nano Footprint : ARDUINO_NANO
Used this selection from the library to represent the Arduino Nano pads on a PCB that accepts the Nano on pin headers.
The footprint, on the Eagle board view, shows the pad layout on the bottom layer. And, a white silkscreen boarder all the way around the board edges on the top view.
However, when the board came back, there was a trace all the way around the board on the top where the silk screen was. This shorts any traces connected to the top pads.
How can I remove the top boarder trace from the library footprint?
AB9A
  • omega-5
    0 omega-5 over 10 years ago in reply to ab9a
    Am 30.08.2016 um 17:45 schrieb Clay Davis:
    For future reference, where did you find this part?
    Clay,
    this library was created by myself . If I can find no suitable
    component, so I create it. This is usually faster than to search
    for it.
    You can find a very good tutorials for creating new parts:
    library_tutorial_eagle.pdf by AkbarSukasdi
    https://cadsoft.io/resources/documentation/1012211595/
    or at:
    https://www.sparkfun.com/tutorials/110
    Freundliche Grüße / Kind regards
    Friedrich
    ... benutzen Sie nntp://news.cadsoft.de und einen
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • ab9a
    0 ab9a over 10 years ago in reply to omega-5
    Friedrich,
    Thank you, so much. This looks good, I'll give it a try.
    Clay
  • omega-5
    - second try
    Am 30.08.2016 um 01:45 schrieb Clay Davis:
    Hi Clay,
    I believe that is not what you need. Here is a modified version
    for use as a component in your own design.
    Friedrich
    Arduino_FB.zip
  • omega-5
    Hi Clay,
    I believe that is not what you need. Here is a modified version for use as a component in your own design.
    Friedrich
    3157.Arduino_FB.zip
