EAGLE User Support (English) How to flip a component on pcb and stay on same side
  • Replies 22 replies
  • Subscribers 190 subscribers
  • Views 5524 views
I have a radial electrolytic capacitor component that lays down on its side. If say it is upright (pins on bottom) and capacitor is bent down, with + on left and - on right.  So now how do I flip it so - is on left and + is on right but capacitor is still upright (pins still on bottom).
Placing it on the other side won't work, as the silkscreen will be on the wrong side.
You can flip component on schematic (for the same reason to reverse the order of pins), but how do you do it  on pcb?
    0 e14 Contributor over 10 years ago in reply to rachaelp
    Yes that is correct.
    I was hoping this feature was supported. Unlike all the previous times this same question was posted (I did a search before posting)  you do see this is a legitimate usage/requirement right?
    I'll just create the variant. I created the original part anyway. Its for a 10x25mm radial electrolytic capacitor so the silkscreen shows the white bar of the negative side.
    Thanks.
  • rachaelp
    0 rachaelp over 10 years ago
    So what you are saying is you have a custom radial part with the silk screen drawn such that is shows the body of the part as it would be with the leads formed to 90 degrees so you can lie it down? I.e. so simple rotation isn't going to work?
    If this is the case I think you need to create an alternative package with your pins the opposite way round so you can then add this to the part as a variant and select it in the board by right clicking and selecting "Package" from the menu. Then you choose your alternative package from the list.
    Best Regards,
    Rachael
