EAGLE User Support (English) How to flip a component on pcb and stay on same side
  • Replies 22 replies
  • Subscribers 190 subscribers
  • Views 5670 views
I have a radial electrolytic capacitor component that lays down on its side. If say it is upright (pins on bottom) and capacitor is bent down, with + on left and - on right.  So now how do I flip it so - is on left and + is on right but capacitor is still upright (pins still on bottom).
Placing it on the other side won't work, as the silkscreen will be on the wrong side.
You can flip component on schematic (for the same reason to reverse the order of pins), but how do you do it  on pcb?
  • rachaelp
    0 rachaelp over 9 years ago in reply to raspyron
    Ronald Laguardia wrote on Fri, 28 October 2016 14:23
    Can't you just bend the pins back the other way?
    I think you missed the point of the original question. The silk screen on
    the board will be wrong if all you do is bend the legs the other way and
    pop it in the board the other way round, not to mention that the reason for
    the OP wanting to flip it on the layout was most likely so the routing goes
    the most convenient way. This is about using radial caps with the leads
    formed to 90 degrees and having the ability to flip it round in the layout
    so the board is correct and shows the correct fitment. The correct answer
    is still to use variants within the device to allow the specification of
    alternative packages with the connections the other way round.
  • raspyron
    0 raspyron over 9 years ago
    0 autodeskguest over 10 years ago in reply to e14 Contributor
    On 05/09/16 19:12, Jerry Sy wrote:
    I think you need to look outside your little bubble. lol.
    Well!
    I have been very polite and helpful to you because I'd assumed you were
    a genuine person looking for help past a slight block. But if you're
    going to respond by being rude then I will certainly not be helping any
    further.
    Am 05.09.2016 um 20:12 schrieb Jerry Sy:
    not to me and a lot of others.
    OK Buster. It is Ok if you speak for  yourself but imho you do not speak
    not for others.
    Those "others" may speak for themselves if they want to.
    And last but not least you don't speak for me. Get that behind your ears.
    Joern Paschedag
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    The fact that if you do a search you will find numerous results discussing this same thing is proof positive this is not intuitive.
    0 e14 Contributor over 10 years ago in reply to rachaelp
    Thanks for the explanation. Now I understand. and the confusion stems from the interchangeable usage of package and variant.
    When one looks at the UI, you see one column called package and a second column called variant.
    When you say add a new variant, the obvious intuitive action is to add a variant to the package.
    It will be less confusing to just say add a new package to the device, then one will right click to add a new package.
    since a package is automatically associated with a variant, I suppose that is where the parlance of add a variant originated from. But since the way the UI is presented distinguishes package and variant, one would add a variant to the package rather than add a new package (with the associated new variant) to the device.
    I hope thread clears up any confusion in the future for anyone searching to find answers and lands on this thread.
    Rachael and Olin have both answered this in their own, respective,
    inimitable ways image However...
    On 05/09/16 08:22, Jerry Sy wrote:
    It is not intuitive.
    Not to you but it seems quite natural to some others.
    Device A
    Package A variant ""
    Package B variant B1
    Package B variant B2
    Package B variant B3
    The way you've written this table clearly illustrates the incorrect
    mindset that makes it seem "not intuitive" to you. As I tried to explain
    before, the correct way to write this is:
    Device A
       Variant ""   -> Package A
       Variant B1   -> Package B
    etc.
    The point is, Variant is a parameter of the DEVICE and NOT of the
    PACKAGE. Get that fact understood and all of the supposed weirdness just
    floats away.
    Jerry Sy wrote on Mon, 05 September 2016 03:22
    Device A
    If you edit B3, the same change appears in B1 and B2.
    No.  You edited B, not B3, so of course variants B1-B3 changed.  Stop and
    actually  think how device definitions work before flailing around or
    delcaring it stupid.
    Each device in a library is a set of bindings between a symbol (what goes
    in the schematic) and a package (what goes on the board).  The binding
    includes information like what pins of the symbol represent what physical
    pads of the package.  Each such binding is called a "variant".  This refers
    to a variant of the device, not any package or symbol.  The various
    bindings within a device need to be uniquely labeled somehow.  That somehow
    is the variant name.
    Devices can currently only refer to a single symbol, but each variant can
    reference any suitable package in that library.  Note that devices
    reference symbols and packages.  The symbol and package definitions exist
    separately in that library.  If you edit a symbol or package, all device
    variants within all devices in that library referencing that symbol or
    package will change.
    If you want two different packages, you have to make two different
    packages.  Then you can point two (or more) variants to those packages to
    use them.  This is what you want.  A package defines physical layout.  You
    want two layouts that are different from each other, so you have to make
    two packages.  Once you do that, you edit the device that references the
    original package and add a variant to reference the new package.  When you
    go to add the device to the schematic, you have to chose between all the
    variants in the package to decide which one you want to use this time.
    Think about it.  This works the way you want it to work and pretty much the
    way it has to work.  Bindings are references and don't contain copies of
    what they are binding in their own private hidey-hole somewhere.  You
    wouldn't want them too.  That would make fixing or enhancing a package a
    mess because you'd have to track down all the bindings that use the package
    and fix all the separate copies.
  • rachaelp
    0 rachaelp over 10 years ago in reply to e14 Contributor
    I think Rob has explained where things got a bit confused quite well so I wont rehash his explanation. In your situation creating package C was the correct things to do. It's still a variant within the device, but it's a variant with a different package.
    In the case above where you have package B pointing to variants B1, B2, B3, a use case for this could be if you have say a standard symbol for an NPN transistor and a SOT-23 package and you create a generic NPN component using these, then there are several combinations of pinouts possible for connecting B,C and E of the symbol to pins 1, 2 and 3 of the package. You use the variants to change the mapping of the symbol pins to the package pads. So in the terminology you gave above:
    Device NPN
    Package SOT-23 variant CBE // Maps pin 1 -> C, 2 -> B, 3 -> E
    Package SOT-23 variant BCE // Maps pin 2 -> B, 2 -> C, 3 -> E
    etc....
    Note, this is not how I do transistors in my libraries but this is an example of how you could use the package variants in a useful way how you were trying to do.
    Best Regards,
    Rachael
    Device A
    If you edit B3, the same change appears in B1 and B2. What's the point?
    I ended up creating Package C.
    If you think about it, it is the exact same part, just positioned differently, so it really is not a different package.
