EAGLE User Support (English) Change the default via  shape
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 1575 views
Pedro147
Pedro147 over 10 years ago
I want to change the default via  shape from square to round and a few people have said to edit the eagle file at "C:\Program Files\EAGLE-7.4.0\scr\eagle" in particular the BRD section
Here is what my default eagle file at the BRD section looks like.
BRD:
MENU '[designlink22.png] Search and order : Run designlink-order.ulp -general;'\
     '[pcb-service.png] PCB Service : Run pcb-service.ulp;'\
     '[idf-3d.png] Export to IDF 3D format: Run eagleidfexporter.ulp;'\
The two edits suggested say to add "CHANGE SHAPE ROUND;"
If I try to do this in the Windows 7 text editor by double clicking the eagle.scr file, when I go to save the edit I am told that I cannot rename the file.
So next I tried to do this in Notepad++ but when I go to save the edited file it asks me to check to see if I have it open in another program which I do not.
It really shouldn't be this hard to change should it? What am I doing wrong please.
  • Pedro147
    0 Pedro147 over 10 years ago
    Just to close this question, I just made a new eagle.scr file with the addition of the required round via shape and replaced the default eagle.scr file with this and my problem is resolved. Thank you all for your help
  • rachaelp
    0 rachaelp over 10 years ago in reply to Pedro147
    Peter Newman wrote:
    Windows is so annoying
    Yes it is image You can always fix that issue though image
  • Pedro147
    0 Pedro147 over 10 years ago in reply to autodeskguest
    Thanks CadSoft Guest. I tried to edit it on my work Windows 7 PC and had no problem editing and saving the eagle.scr file. This did change the default via shape from square to round. I might just copy this modified file and replace the one on my home PC with it instead. Windows is so annoying as I am the administrator of the account and have set myself to have access to everything. I should be used to the way it operates I suppose image
    0 autodeskguest over 10 years ago in reply to autodeskguest
    Am 07.09.2016 um 12:37 schrieb Morten Leikvoll:
    Windows problem image
    I guess thats just half the truth image
    Cadsoft has not put any resources into making a good windows "app". Yes
    it sucks that you have to take care of that in a separate os-specific
    way. I have no idea if QT can help there. Like linux wants their scripts
    maybe in the /etc folder, windows have a os specific path as well.
    Configuration files should not lie in the protected executable area. And
    executables should not be installed on any root drive.
    I myself manually install the exe in the protected area, and if cadsoft
    just installed the user/config files into the proper location (roaming
    or local userprofile), everything would work just fine (I think, Im not
    a professional windows developer)..
    Hi Morton,
    if I overdo a little, I don't even know how to spell windows image
    I have different logical drives on my win system 8.1/64 but since ages I
    install eagle like this example:
    On  setup I tell win to install eagle in E:/eagle-6.6.0 i.e.
    After that I install my libraries and projects in different locations.
    In control panel I enter the paths to the locations and that is it.
    On my C-drive is windows only and nothing else.
    I also run an eagle 5 installation and by using the U-parameter I
    instruct each eagle what location and name to use for the eaglerc.usr
    file. (I.e. eaglerc-512.usr located somewhere)
    So no sweat image
    Joern Paschedag
    On 07.09.2016 12:03, Joern Paschedag wrote:
    Am 07.09.2016 um 11:49 schrieb Peter Newman:
    BRD:
    -general;'\
    rename the file.
    wrong please.
    https://www.element14.com/community/message/205288
    BRD:
    Joern Paschedag
    BRD:
    -general;'\
    rename the file.
    wrong please.
    You may need to start your text editor in administrator mode to save to
    it. The file lies in a protected area.
    I should specify how.. Right click your editor program icon, choose "run
    as administrator".
    BRD:
