EAGLE User Support (English) Draw Transmission Line using Eagle
  • Subscribers 189 subscribers
  • Views 2336 views
  • eagle
  • line
  • transmission_line
  • transmission
I am using Eagle as the PCB Design and Layout tool.I wanted to use an Antenna on the chip. For that I required a transmission line of about 50 ohm impedance between CC3200 pin and Band Pass filter. I cannot find any tool which will help me in drawing the transmission line of that particular impedance using Eagle. I need a 50 ohm transmission line but I don not know how to draw this on Eagle.
Kindly provide some guidance.
Turn to chapter 6 of attached CC3200 datasheet for seeing that 50 ohm tx line.
Thanking You.
imagecc3200 datasheet.pdf
  • jc2048
    0 jc2048 over 10 years ago
    Have you looked at these guidelines relating to their reference design for the chip?
    http://www.ti.com/lit/ug/swru370a/swru370a.pdf
    Look in section 4. They show how to lay out the transmission line for their particular board stack. Understand what they are doing and why even if you then want to adapt it for a different stack-up.
    Curiously, on their board layout, the trace to the filter is the least critical of the rf traces (because it is so short it hardly constitutes a transmission line), so I don't know why they've singled it out on the schematic in preference to the others.
  • rachaelp
    0 rachaelp over 10 years ago in reply to rachaelp
    There is also this tool here: https://www.saturnpcb.com/pcb_toolkit.htm
    Use the 'Conductor Impedance' section to work out how to create traces with the desired impedance. You'll need to know your board stackup, or have some ability to specify your stackup requirements to you PCB manufacturer.
    Best Regards,
    Rachael
  • rachaelp
    So I think what the datasheet is saying is that the trace between the RF_BG pin (31) on the cc3200 and the 2.4GHz filter needs to be impedance matched to 50 ohms.
    There are various factors here, the stackup of the PCB, e.g. where is the ground plane? What is the distance to the ground plane? What is the board material? etc. Also, is this routed on an outer or an inner layer? What is the trace width? All these factors determine the trace impedance.
    Now, if you require very accurate impedance control then you will need to speak to your PCB manufacture and get them to define a layer stackup for you to give the target impedance required on the layer you are running this trace. They will then tell you the trace width to use to achieve your target impedance. Alternatively do a google search for PCB stackup calculators and something will probably pop up that you could use.
    Best Regards,
    Rachael
