EAGLE User Support (English) Library part not visible in the schematic editor
  • Views 679 views
  • eagle library
  • eagle schematic
amangg
amangg over 10 years ago
I have recently added a new library to the eagle. Some parts are visible when opened in the library but when can't see them when adding a new part in the schematic editor.
Any possible ways to sort this out?
  • dukepro
    0 dukepro over 10 years ago
    If you already had the library in question in USE, then you need to do a
    Library-->Update from the schematic.
    Hi
    You won't see libraries when you attempt to ADD unless you USE them.
    In the Control Panel you will see a green dot beside the libraries that
    have been USEd. Click on the dot to turn it green or grey.
    See the HELP and search for USE and look under Editor Commands
    HTH
    Warren
