EAGLE User Support (English) Best way to upgrade
  • Replies 25 replies
  • Answers 13 answers
  • Subscribers 189 subscribers
  • Views 4628 views
Best way to upgrade
jsantosrico
jsantosrico over 10 years ago
The default behaviour of Eagle is to keep old versions of eagle when you update. Is not really a problem, as it is not hughe program, but it's a tad annoying when I click an old link pointing to an old version or I double click on a file and it opens in the old version because the file association has not updated. Why is this the default behaviour? I also noted that in my projects there is a file called Eagle.epf, which lists the libraries in use in my project, and the default libraries still point to old versions of them, as in for example:
UsedLibrary="C:/EAGLE-7.6.0/lbr/19inch.lbr"
UsedLibrary="C:/EAGLE-7.6.0/lbr/40xx.lbr"
UsedLibrary="C:/EAGLE-7.6.0/lbr/41xx.lbr"
UsedLibrary="C:/EAGLE-7.6.0/lbr/45xx.lbr"
Do I have to check all my projects every time I upgrade and update to the new paths? Is that the way this is intended to be? I was wondering if there is a less cumbersome way to update.
Thanks for taking the time to check my problem.
regards,
Joel
    0 autodeskguest over 7 years ago in reply to dukepro
    Am 04.09.2019 um 23:15 schrieb Chuck Huber:
    On 9/4/19 11:47, Joern Paschedag wrote:
    Am 04.09.2019 um 13:57 schrieb rachaelp:
    Hi Joern,
       wrote:
      Hi Rachael,
    I don't feel bothered
    On the other hand I don't consider you as a long time user (around 2016
    I guess)?
    I've been using EAGLE professionally since early 2015 but on and off
    for personal projects way before that, but I was only active on the
    forums from 2015. Prior to using EAGLE for my main work I used Mentor
    Graphics and Cadence products for many years so I know what higher
    end tools are like and what the features add to the workflow.
    SNIP
    I see image
    I started with Orcad...
    Yeah.. that's pretty close to where I started.
    Orcad schematic and Tango PCB in the early-mid 80's.
    I'm not entirely sure when I cut over to Eagle.  I do know it was
    sometime in version 4.
    Enjoy,
        - Chuck
    I just checked, I started with eagle 2.6, still have the Cadsoft folder  image
    with 5 1/4" diskettes and no drive for them image
    The reason was actually that I had to construct plenty devices with
    European symbols in orcad.
    When eagle came out we had both the US- and EU-Symbols and we even could
    convert the orcad files to eagle.
    Unfortunately there was no hierarchical design in eagle but was no so
    important at that time.
    Joern Paschedag
  • dukepro
    0 dukepro over 7 years ago in reply to autodeskguest
    Hi Joern,
       wrote:
      Hi Rachael,
    I guess)?
    SNIP
    I see image
    Enjoy,
        - Chuck
    7455.att1.html.zip
    0 autodeskguest over 7 years ago in reply to rachaelp
    Hi Joern,
      wrote:
    Hi Rachael,
    I guess)?
    I've been using EAGLE professionally since early 2015 but on and off for personal projects way before that, but I was only active on the forums from 2015. Prior to using EAGLE for my main work I used Mentor Graphics and Cadence products for many years so I know what higher end tools are like and what the features add to the workflow.
    SNIP
    I see image
    Joern Paschedag
  • rachaelp
    0 rachaelp over 7 years ago in reply to autodeskguest
    Hi Joern,
    autodeskguest  wrote:
    Hi Rachael,
    I don't feel bothered image
    I guess)?
    Same thing is  AD's "condition of use".
    Have you ever read through the whole of it? Especially I "like" position
    9 and 11.1.
    Well I can certainly understand that the wording of these may cause some concern....
    Well I see that a little different. What I have seen in the the update list is that most of the new updates are repairs of a few new things.
    Certainly a lot of what is listed in the release notes is related to enhancement/fixes to existing features but having read through it now the release notes aren't always doing a good job of highlighting all the new features properly. There is a lot more than is immediately obvious from a scan through the release notes. Here is a list of the things I can think of:
    • Shared Managed Libraries
    • Design Manager in Schematic
    • Persistent Groups
    • Re-Route Command
    • New Routing Engine with new Bus Routing and enhanced Diff Pair Routing
    • Selection Filter and Object Inspector
    • Assign 3D models in Sch/Brd
    • Quickroute Fanout
    • Preserve Angles Move in Board
    • Digital/Mixed Simulation
    • Design Manager in Board
    • New Bus UI functionality in the schematic
    • New CAM Processor
    • Analog SPICE Simulation
    • Routing enhanced with Object Avoidance, Loop Removal, Push & Shove, Etc
    • Live DRC
    • Fusion 360 Integration
    There's probably a lot more I have forgotten too, not that I expect you care at this point image
    Best Regards,
    Rachael
    Am 03.09.2019 um 17:58 schrieb rachaelp:
    Hi Chuck,
    It's great to hear from you and thank you for replying on this.
      wrote:
    I wouldn't call it a shame that long time users such as myself aren't using the newer AD versions of Eagle.
    I guess what I should have said was I personally find it a shame that the situation has lead to a lot of the long time EAGLE users to not being involved in how EAGLE has progressed, and not being on those forums. I always found your and many others insights invaluable. So it's me personally wishing the situation was different and you guys would be involved in the new EAGLE forums again. I really do understand and respect your position on this but still hope that some day something can be done to improve this situation.
    Hi Rachael,
    I guess)?
    And I shall not start again a discussion about the old stuff.
    But what you don't know is during that time after some long open
    discussions some others and I  got private offers from AD about licensing.
    Imho behind the back of all the other users.
    9 and 11.1.
    THAT certainly takes time  (that is made so to lull one in, put one asleep)
    but I always do read through the whole thing and those conditions are
    not acceptable for me.
    Imho it shows the character of AD and I don't like it.
    I don't know if you have even looked casually at the more recent changes, but for me the productivity increase over what I can do in 7.7 for the boards I do is massive and at least some of the early accusations levelled at AD that they were just in it to fleece people for the subscription money have been proven false.
    AD corporate licensing policies aside, it seems to be a really genuinely enthusiastic bunch of engineers working on bringing new features to EAGLE and it's a shame for them too that no matter how hard they work and how much they add to the product, there are a large portion of the potential user base who are not going to use what they are producing.
    Joern Paschedag
  • geralds
    0 geralds over 7 years ago in reply to dukepro
    Basically, I think like you. But Autodesk does not care how many cope. That was so every time, with all their products they sell.
    "If you like that, or need that - then pay that!"
    I recall too what we discussed here.
  • rachaelp
    0 rachaelp over 7 years ago in reply to dukepro
    Hi Chuck,
    dukepro  wrote:
    Rachel, It is sincerely enjoyable to exchange ideas with you.  I look
    forward to the next time we can engage.
    Likewise, hopefully our paths will cross again in the not too distant future.
    Best Regards,
    Rachael
  • dukepro
    On 9/1/19 03:27, Joern Paschedag wrote:
    Am 31.08.2019 um 15:33 schrieb rachaelp:
       wrote:
    I don't use the AD versions
    It's a shame more of the long time users of the original EAGLE like
    yourself aren't using the newer AD versions
    A shame is AD's attitude...
    Good afternoon, Rachael,
    Like Joern, myself, and others, you're a long time user of Eagle.  I
    recall that you were vocal regarding AD's licensing policy.  I was as
    well.  I believe that we engaged each other in a... not heated... but an
    "energetic" debate, which I found quite enjoyable.  We both were able to
    clearly convey our respective policies.  While I understand your view on
    this, I have not adopted it as my own.
    using the newer AD versions of Eagle.  We're probably missing out on
    some new features and such, but we're getting along with the pre-8.0
    versions.  My company hasn't had a compelling need for anything more
    feature rich that 7.7.  Instead, it's more of a disappointment that AD
    is not willing to provide an off-line or perpetual license.
    The true shame lies with AD when, despite their promise, they absolutely
    refused to accommodate users needing a perpetual license.  I mean, they
    weren't even will to enter into one-on-one negotiations.  And /that/ is
    to what Jeorn eluded.
    Just for completeness, Eagle is not the only AutoDesk product I can't use.
    For now, I'll continue using Eagle 7.7.  When I need new features, I'll
    look elsewhere... but not to AutoDesk, at least not until they willing
    to negotiate in good faith.
    Enjoy,
        - Chuck
    3051.att1.html.zip
    It's a shame more of the long time users of the original EAGLE like yourself aren't using the newer AD versions, your experience and support on the main AD forums would be very valuable and I'm sure if you could look past the licensing (which I assume is your reason for not using it), it's actually really really good now. It's like EAGLE on steroids, the last few releases in particular have been big jumps up in functionality.
    Best Regards,
    Rachael
    https://www.element14.com/community/message/280300
    Joern Paschedag
    0 autodeskguest over 7 years ago in reply to autodeskguest
    Am 31.08.2019 um 11:44 schrieb Rob Pearce:
    On 31/08/2019 08:35, Joern Paschedag wrote:
    I don't use the AD versions but think that this parameter still exist.
    Check documentation.
    Yes, it still exists, and is very useful for having V9, V8, V7 and V5
    all available on the same PC, in case I need to work on an old design
    and don't want to convert it.
    That is exactly the reason why I keep old versions image
    Joern Paschedag
