EAGLE User Support (English) Controlling the temperature of gas chromatography using CAL 3300
  • Views 317 views
mabourg
mabourg over 9 years ago
I am working on a part of my project which has to do with temperature control of a gas chromatography. I purchased Farnell CAL3300 temperature controller to carry out this function.
My aim is to use the CAL 3300 with associated components such as type K sensor (thermocouple), Solid state relay (SSR) and heater (Load). The electrical connection is such that the CAL 3300 has a separate supply source while the power supply to the heater is terminated through the SSR.
The challenge i am having is that after repeatedly running tuning at set-point, the controller (CAL3300) does not maintain the temperature of the heater at the desired set-point.
Kindly advise me on what to do.
David
  • dukepro
    0 dukepro over 9 years ago
    David,
    My advice is to post your request in a different newsgroup.  This
    newsgroup is for support of Cadsoft's Eagle program.
    Best regards,
        - Chuck
    On 10/18/2016 05:12 AM, David Abogunrin wrote:
    David
    https://www.element14.com/community/message/207672
