EAGLE User Support (English) Can not draw trace narrower than 10mil
  • Subscribers 187 subscribers
  • Views 387 views
zhangz64
zhangz64 over 9 years ago
I importe the design rule from a pcb manufacturer. The minimum trace width is 5mil.
However, when i route the trace, i could not select any trace width  smaller than 10mil.
I check the net class as well. The value is defined as 5mil.
Same for the via, I could not use via size smaller than 20mil.
How do i change my trace with value to smaller than 10mil?
I am using version 7.6 professional.
Eddy
    0 autodeskguest over 9 years ago
    Have you tried typing in the size you want? Most of Eagle's drop-downs
    are edit boxes too. Or use the command entry and type "change width 5;"
    or similar.
    or similar.
