EAGLE User Support (English) How to import that pattern you want to print on the surface of your PCB in EAGLE?
  • Subscribers 187 subscribers
  • Views 403 views
sheepjms
sheepjms over 9 years ago
I want to print a pattern covering on the surface of the PCB.it looks like this:image
I transform it into .bmp format and then import to EAGLE, it said 'bmp file contains more than 256 colors, reduce colors before use.'
Anyone can help me out?
    0 autodeskguest over 9 years ago
    https://www.element14.com/community/message/209006
    Hi Ms.James,
    I hope you're doing well. Open the bmp file in a program like Paint (or
    GIMP, or Photoshop) and save the file as a Monochrome bitmap. This will
    make sure the file only has two colors (Black and white). Now you should
    be able to import it successfully.
    Best Regards,
    Jorge Garcia
