EAGLE User Support (English) How to save the file with Ratsnest.
  • Subscribers 187 subscribers
  • Views 1614 views
  • eagle help
  • eagle pcb
dpiralis
dpiralis over 9 years ago
I use Polygon GND and  Ratsnest to make GND plate.. but when I reopen or sent the file to manufacture  Ratsnest is not enabled and GND unoconnected wire is nowhere. So they will print the board without GND. How to save the file like on the first image?
    0 autodeskguest over 9 years ago
    Dimitris Piralis wrote on Tue, 06 December 2016 15:55
    I think you mean "plane"?
    This make no sense at all.  RATSNEST is not enabled or disabled.  It is a
    command you can run in the board editor in Eagle.  With the right setting,
    RATSNEST will compute polygons and show you them filled.
    This has nothing to do with the manufacturer.  The Gerber files you send
    them contain whatever information you chose to have the CAM processor write
    out.  It is a good idea to check the Geber files with a Gerber file viewer
    before sending them to the board house.  You should see the ground plane.
    If not, go back to Eagle, fix the CAM settings, and re-make the Gerber
    files.
    Maybe.  Good board houses just do what they are told via the Gerber files.
    It's annoying when your board is held up because the board house thinks
    something isn't how you may have intended it, but some board houses do
    that.  This is more likely when you are using a prototype process or the
    board house aims more at hobbyists.
    In any case, make sure to give them specs for exactly how to make the
    boards.  That's your job as the electrical engineer.  It's their job to
    follow those specs and produce the boards as you specified.  If done right,
    the only reason you don't get boards as you wanted is if you didn't specify
    what you really wanted.  Fortunately, Eagle makes specifying a board
    correctly quite easy with the DRC checks and the CAM processor.
    You need to learn how boards are made and how the interface to board houses
    work.  You don't "save as" or some such in Eagle.  You run the CAM
    processor to create standard Gerber files.
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    You don't. The flood fill is performed "as needed". IF your board house
    accepts Eagle files then they know how to cope. If not, you need to
    produce Gerbers using the CAM processor, which automatically does the
    flood first. There is no issue here.
    https://www.element14.com/community/message/210686
    Due to the time it takes to fill ratsnests on large complex boards it is
    not done when you open a project. The Cam processor fills them when
    making the output.
    Paul
