EAGLE User Support (English) Eagle 4.16 / Win10 - Very slow redraw - any solution?
  • Subscribers 187 subscribers
  • Views 2049 views
tony1980
tony1980 over 9 years ago
Is there any solution for the very, very slow redraw (both in schematic and board editors) with Eagle 4.16 on Windows 10?
Originally purchased Professional edition 4 of Eagle years ago and used on a XP machine for years without issue. Now migrating to new laptop and installed my Eagle on Windows 10 and the redraw is horrendously slow - with my designs taking 5-10 seconds every time the viewpoint is moved and I can see it slowly build up on screen - so it's impossible to work with at this pace!
When checking on Cadsoft's site the upgrade cost for my license to Eagle 7 Ultimate is nearly 600 euros so that's currently not an affordable option. Have had to resort to creating a virtual machine running XP to continue my work.
    0 autodeskguest over 9 years ago in reply to autodeskguest
    Hello Rob,
    Rob Pearce prodded the keyboard with:
    On 08/12/16 15:48, Baron wrote:
    As far as I am aware, Windows has never been able to run any Linux
    binaries,
    The lack of useful command line tools in Windows has been such a
    pain for developers for so long, and environments like cygwin so
    popular as a result, that MS have finally tried to fix it... by
    implementing a "brand new compatibility concept" of providing a
    wrapper for the Linux API to map it to Windows API. In other words,
    a direct opposite clone of "Wine", which has been available on Linux
    for years. This new wrapper allows most of Ubuntu to be installed
    within Win10. However, like Wine before it, there are severe limits
    on compatibility and I doubt Eagle would run within it.
    Thank you for that information. The last version of Windows that I had
    anything to do with was Vista. I used to run Wine just so I could run
    LTSpice, but that's all.  Nowadays Linux serves all I need.
    Best Regards:
                          Baron.
    binaries,
    The lack of useful command line tools in Windows has been such a pain
    for developers for so long, and environments like cygwin so popular as a
    result, that MS have finally tried to fix it... by implementing a "brand
    new compatibility concept" of providing a wrapper for the Linux API to
    map it to Windows API. In other words, a direct opposite clone of
    "Wine", which has been available on Linux for years. This new wrapper
    allows most of Ubuntu to be installed within Win10. However, like Wine
    before it, there are severe limits on compatibility and I doubt Eagle
  • tony1980
    0 tony1980 over 9 years ago in reply to autodeskguest
    Thanks for your responses - I had already tried the XP Compatiblity modes when I had it installed on Windows 10 and that did not make any difference in speed for me.
    As I now have it running properly under a XP Virtual Machine there is no need for me to try the Linux version under a Linux VM. I was just looking for a solution to run it natively without the horrendous slow down!
    Paul Romanyszyn prodded the keyboard with:
    On 12/08/2016 06:11 AM, Tony Thompson wrote:
    affordable option. Have had to resport to creating a virtual
    https://www.element14.com/community/message/210770
    Eagle uses some video driver calls that are not used by many
    programs. Still running 4.xx but under Linux. Gave up windows when
    95 was broken by backported 98 video driver.
    Under Linux 4.16 does work with compositing mode of the window
    manager. All the windows are transparent.
    It would be a lighter setup to run Linux in a virtual machine and
    install the Linux version.
    What I have read that Win 10 seems to support running Linux binary
    files. Here is the link to version 4.16
    ftp://ftp.cadsoft.de/eagle/program/4.16r2/
    Maybe some one with win 10 is up to speed on that possibility.
    Paul
    binaries,  It is however possible to run a Linux virtual machine
    inside Windows. Since M$ is moving to a "Pay to use" model, moving to
    Linux might be a more sensible way to go.
    Best Regards:
                          Baron.
    I also have Win 10 and EAGLE 4.16 (and newer versions). I just ran EAGLE
    using XP SP3 compatibility mode. (properties/compatibility) Redraws are
    noticeably slow, but no more than a second. I think that 5 - 10 second
    redraws would drive me crazy!
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    When checking on Cadsoft's site the upgrade cost for my license to Eagle 7 Ultimate is nearly 600 euros so that's currently not an affordable option. Have had to resport to creating a virtual machine running XP to continue my work.
    Eagle uses some video driver calls that are not used by many programs.
    Still running 4.xx but under Linux. Gave up windows when 95 was broken
    Under Linux 4.16 does work with compositing mode of the window manager.
    What I have read that Win 10 seems to support running Linux binary files.
    Paul
