EAGLE User Support (English) How do I Export a png file for silkscreen when a file does not show up and export to clipboard does not produce a file to be found in Freeware version on Windows Xp computer?
  • Subscribers 190 subscribers
  • Views 1274 views
  • .brd
megakbyrne
megakbyrne over 9 years ago
I am new to Eagle and need to export a png file to manipulate in Inkscape for silkscreen purposes. Is there a tutorial that I may view to teach me how? I draw a blank when trying to locate a file to export in window Export? How do I resolve this problem?
  • megakbyrne
    0 megakbyrne over 9 years ago
    My Eagle is not generateing a CAM file like a U-Tube video just stated. What is available online to generate CAM files and ulp files to import into Eagle for Board houses to produce a brd with silkscreen layer. So in the end there is no file for Eagle to find.
  • techsupport
    0 techsupport over 9 years ago
    https://www.element14.com/community/message/210791
    Click on file/export/image, in the dialog box click on the BROWSE
    button, at this point you can select file type and path.
    Ed
  • megakbyrne
    I went into Eagle and highlighted all and still it does not generate a png file because i know where
    all .sch files and .brd files are. I made doubly sure that silkscreen was highlighted.
  • rachaelp
    0 rachaelp over 9 years ago in reply to megakbyrne
    Hi Kevin,
    I just tested this out on one of my boards to make sure it works, and as
    Jorge said, File->Export-Image then select where to put the file and the
    file type and click OK. For me if I don't specify an alternative location
    it puts the file in the same filter as the .brd and .sch files.
    Best Regards,
    Rachael
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • megakbyrne
    0 megakbyrne over 9 years ago in reply to autodeskguest
    I just tried out what you said an there still is no file to be located in My Documents under Eagle files? what am I missing as I can locate all files under any project except with Export command?
    0 autodeskguest over 9 years ago
    Hello Kevin,
    I hope you're doing well. Make sure to have the silkscreen layer on and
    then go File > Export > Image. You can specify the filetype there when
    you click Browse.
    Best Regards,
    Jorge Garcia
