EAGLE User Support (English) Part number formatting
  • Subscribers 190 subscribers
  • Views 944 views
jsantosrico
jsantosrico over 9 years ago
I would like to know if it's possible to change the part number formatting. In particular, I would like to know if it's possible to pad the numbers so instead of getting R1, R2,... I can get R01, R02,....
I ask this because it's a bit annoying to short my BOMs and get R1, R11, R12, ..., R19 and then R2, R20, R21, ..., R3 and so on.
Thanks!
  • dukepro
    0 dukepro over 9 years ago
    Thanks!
    https://www.element14.com/community/message/210932
    The reason this happens is because the sort order is determined by
    what's called an "alpha sort", where each character in a string is
    compared to its corresponding character in a second string based on the
    ASCII value of each character.  (To be complete, other character sets
    may be used based on locale.)  There is no interpretation of the meaning
    of each character (digit vs. letter).  Since the comparison is done on a
    character by character basis, all the 1's will sort ahead of all the
    2's, for each character position.  i.e. the comparison does not try to
    interpret the value of a string of digits.
    Thus, R1, R10, R123, R19, R1.)
    For the devs:
        Man page: http://man7.org/linux/man-pages/man3/strverscmp.3.html
        strverscmp(3) is available when GNUSOURCE is defined.  This should
        allow it to be pulled from glibc on demand on linux platforms.  I'm
        not sure where this falls on Mac or Windows machines.
        Alternatively, just include the source in the build.
        Source can be found at:
        https://opensource.apple.com/source/bison/bison-14/lib/strverscmp.c
        and many other places.
    As for implementation in the User Language, I would suggest adding
    strverscmp() to the list of builtin functions.
    Also, a variant of the builtin ULP sort() function, perhaps called
    sortver(), can use the above comparison function to determine sort order.
    The icing on the cake would be to enhance the builtin fileglob()
    function to allow a version sort on file names, just as versionsort(3)
    does for DIR entries retrieved by scandir(3).
    See: http://man7.org/linux/man-pages/man3/versionsort.3.html
        Syntax
            int fileglob(string &array[], string pattern[, ALPHA_SORT |
        VERSION_SORT]);
        Builtin constants of appropriate value can be added accordingly.
        The default would be an alpha sort to maintain backward
        compatibility of this function.
    In summary, it would be really nice to have a sortver() function.  While
    Joel, the original poster, described a problem, I would like to ask for
    the above modifications to the ULP, namely:
    • add strverscmp() to the list of builtin string functions,
    • add sortver() as a function that does the same thing as sort()
        except that it would use strverscmp to compare two elements of an
        array, and
    • modify fileglob() to accept an optional third argument indicating
        whether the resulting set of file names is sorted cannonically or by
        version.
    Ideas?
    I wish all a happy and prosperous new year!
    Best regards,
        - Chuck
    7380.att1.html.zip
  • jsantosrico
    0 jsantosrico over 9 years ago in reply to rachaelp
    Thanks Rachael,
    that will do the trick, although as you mention is not exactly what i need, I really don't mind that the numbering is in the hundreds.
    0 autodeskguest over 9 years ago
    Hi
    Where are you getting this sorted order from? A ulp perhaps? Please
    explain.
    There are ways in Excel to get it ordered that way if that is where you are
    doing it, according to Google.
    Warren
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • rachaelp
    0 rachaelp over 9 years ago
    Hi Joel,
    You could use the renumber function found in Tools->Renumber parts....
    Set the numerical order at say 100 and then everything on sheet 1 will start from 100, on sheet 2 from 200 and so on. It's not quite what you asked for but it will satisfy your need for correct numerical ordering.
    Best Regards,
    Rachael
